Why it must call cuGraphicsUnregisterResource after cudaMemcpy from surfacebuffer to cuda memory
My jetpack version: 5.1.2 and AGX Orin with 64G.
I mapped surfacebuffer to cuda memory then use cudaMemcpy to other cuda memory:
 if (-1 == NvBufSurfaceMapEglImage(surface_, 0)) {
    AERROR << "Failed to map surface.";
    return false;
  auto eglImage = surface_->surfaceList[0].mappedAddr.eglImage;
  CUresult status;
  status = cuGraphicsEGLRegisterImage(&pResource_, eglImage,
                                      CU_GRAPHICS_MAP_RESOURCE_FLAGS_NONE);
  if (status != CUDA_SUCCESS) {
    AERROR << "cuGraphicsEGLRegisterImage failed: " << status
           << ", cuda process stop";
    return false;
  status = cuGraphicsResourceGetMappedEglFrame(&eglFrame_, pResource_, 0, 0);
    AERROR << "cuGraphicsSubResourceGetMappedArray failed";
    return false;
  status = cuCtxSynchronize();
    AERROR << "cuCtxSynchronize failed";
    return false;
  gpu_address_ = static_cast<uint8_t*>(eglFrame_.frame.pPitch[0]);
  cuAssert(cudaMemcpy(gpu_address_, cuda_memory,
                      src.cols * src.rows * src.elemSize(),
                      cudaMemcpyDeviceToDevice));
  cuGraphicsUnregisterResource(pResource_);
Actually I want call cudaMemcpy multi-times, but everytime I call cudaMemcpy must followed with cuGraphicsUnregisterResource, otherwise it will lost image data.
Could you tell me the reason? And is there any better API to call?
BR/Tim
cuGraphicsUnregisterResource is to release resources registered by the cuGraphicsEGLRegisterImage.
It isn’t used by cudaMemcpy.
Would you mind sharing a complete source code to reproduce the lost image data issue?
We want to check it further.
Thanks,
