-finstrument-functions is one of GCC’s features. But when i try to add this flag to kernel build as below, build would failed with error. Could you help to check how to fix this? Thanks!
@DBrisingr@ShaneCCC This build error cause after I add -finstrument-functions flag to KBUILD_CFLAGS. The complete log after this change please check attached ff.log.
And later I add attribute ((no_instrument_function)) to the function rise above error. Then there’s not compiling error, but report section mismatch error when link vmlinux. Please check attached ff_aa.log.
Follow the note, set CONFIG_SECTION_MISMATCH_WARN_ONLY=y to the project config, the build success finally-check ff_smwo.log. But once I run the test, the HDMI output chaos firstly, then system freeze and reboot.
For more detail about this issue and background. I suspect there’s a memory overflow access in my system. So i want to use GCC finstrument-function which could set a hook to each function entry and exit to locate this issue. Refer to http://www.logix.cz/michal/devel/CygProfiler/cyg-profile.c.
Could you please help to verify on your build and fix this? Thanks!
BTW no other modification to build command/configuration.ff.log (38.9 KB) ff_aa.log (22.1 KB) ff_smwo.log (21.1 KB)
The hook i put to the __cyg_profile_func_enter/exit is just to check a suspect tegra_spi_data member address which assigned to a global pointer in premised.
Sorry, maybe due to some command line misconfiguration. I found the logs uploaded last time weren’t complete. Just update ff_aa.log and ff_smwo.log with complete error/warning info. And for ff.log, since build would take long time, the entire error message is as the snipping picture. I wouldn’t update new one. Thanks!
Generate instrumentation calls for entry and exit to functions. Just after func- tion entry and just before function exit, the following profiling functions will be called with the address of the current function and its call site. (On some platforms, __builtin_return_address does not work beyond the current func- tion, so the call site information may not be available to the profiling functions otherwise.)
void __cyg_profile_func_enter (void *this_fn, void *call_site);
void __cyg_profile_func_exit (void *this_fn, void *call_site);
Did you add the _profiler function definitions correctly? I can reproduce the same error locally. Also, if I understand correctly, you want to instrument each function with a callback right? Why not try Linux’s inbuilt ftrace with hooks Using ftrace to hook to functions — The Linux Kernel documentation. This could be much more easier than doing it manually as you have tried.
@DBrisingr Yes, i want to instrument each function with a callback. For my use case, i need to call my callback not only at entry, but also when a function exit. So that i can know the exact place where the expect event triggered.
And update about this issue. Later debug found if i only add this flag to SPI module(add to subdir-ccflags in SPI module makefile). The profiling function works without any issue. But if add to KBUILD_CFLAGS globally, it would cause system reboot as mention above. That’s i can only monitor/add callback to one module, but not full system. Could you help to check again? Thanks!
