Hi, I am working on a program that using DGEMM for matrix multiplication. The compiler I am using is pgi 707/pgf77. In this program the subroutine DGEMM has been parallelized already:
C$OMP Parallel
C$OMP Single
C$ NP=omp_get_num_threads()
C$ MinCoW=16
C$OMP End Single
C$OMP End Parallel
ColPW = Max((N+NP-1)/NP,MinCoW)
NWork = (N+ColPW-1)/ColPW [i]!...N is the number of column of C(M,N).[/i]
If(XStr2.eq.'T'.or.XStr2.eq.'C') then
IncB = 1
else
IncB = LDB
endIf
IncB = IncB*ColPW
IncC = ColPW*LDC
C$OMP Parallel Do Default(Shared) Schedule(Static,1) Private(IP,XN)
Do 100 IP = 0, (NWork-1)
XN = Min(N-IP*ColPW,ColPW)
Call DGEMM(XStr1,XStr2,XM,XN,XK,Alpha,A,XLDA,B(1+IP*IncB),
$ XLDB,Beta,C(1+IP*IncC),XLDC)
100 Continue
The BLAS library I use for compiling this code is:
pgf77 -i8 ‘-mcmodel=medium’ -mp -O2 -tp p7-64 -Mreentrant -Mrecursive -Mnosave -Minfo -Mneginfo -time -fast -Munroll -Mvect=assoc,recog,cachesize:2097152 -o xgemm.exe xgemm.o $gdvroot/bsd/libf77blas-em64t.a $gdvroot/bsd/libatlas-em64t.a -lpthread -lm -lc
Now the problem is:when I run the matrix multiplication jobs (the size of the matrices is 3432X3432) parallelized, upto 7 processors the speedup is perfect, but once the jobs are parallelized by 8 processors, the speedup becomes really poor (less than 3 times). However, when I change the size of the matrices, e.g. 924X924, the speedup for 8 processors becomes normal. I tried to assemble more memory for the 3432X3432 matrix multiplication of 8 processors, but it seems the speedup for a 10GB memory (the limit of our hardware) is still the same. Any one here can help me? Thank you very much!!!
