• Hardware Platform: GPU
• DeepStream Version: 6.2
• Language: cpp
I am getting the message.value in kakfa like the following -
"version" : "4.0",
"id" : "161",
"@timestamp" : "2023-05-15T01:27:37.528Z",
"sensorId" : "0",
"objects" : [
"1|501|491|825|923|Person|#||0||||0.970665|#|pose3D|pelvis,-185.179886,944.170349,2601.482910,0.274170|left-hip,-174.041702,831.402771,2602.955078,0.153687...
Here “objects” is an array of strings separated by “|”. I want it to be the key-value pair.
A portion of code in deepstream application -
NvDsEventMsgMeta *msg_meta = (NvDsEventMsgMeta *)g_malloc0(sizeof(NvDsEventMsgMeta));
NvDsPersonObject *msg_meta_ext = (NvDsPersonObject *)g_malloc0(sizeof(NvDsPersonObject));
msg_meta->type = NVDS_EVENT_ENTRY;
msg_meta->objType = (NvDsObjectType)NVDS_OBJECT_TYPE_PERSON;
msg_meta->bbox.top = obj_meta->rect_params.top;
msg_meta->bbox.left = obj_meta->rect_params.left;
msg_meta->bbox.width = obj_meta->rect_params.width;
msg_meta->bbox.height = obj_meta->rect_params.height;
msg_meta->extMsg = msg_meta_ext;
msg_meta->extMsgSize = sizeof(NvDsPersonObject);
