Why might a Recovery Boot get forced?
Hello, I am facing within the bootloader the issue that it is attempting a Recovery Boot instead of direct or GRUB boot.
I haven’t picked it in the UEFI and changing settings there under:
Device Manager>NVIDIA Resource Configuration>L4T Boot Mode
does not affect it.
I am using a JNX30D from AUVIDEA as carrier board and a NVMe SSD as install location (Jetpack 5.0.2).
My Serial dump:
**  WARNING: Test Key is used.  **
  Error: Could not detect network connection.
L4TLauncher: Attempting Recovery Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
Same is displayed on the boot screen.
If there is anything happening afterwards (and in case it should boot up L4T/Ubuntu), I cannot tell as I have disabled nvgetty.
However, on the screen there is only a cursor blinking in the top left corner like there was no boot device found.
In the UEFI menu I can still find the SSD.
What might be the reason(s) for it to be triggered or where do I find documentation about this boot mode?
hello pastap,
are you going to flash to an external storage device?
please also change the Boot Order Selection.
Hello @JerryChang ,
I have not planned to flash.
Sorry, I should have mentioned explicitly, that I had a running system before.
So it booted successfully to Ubuntu on the SSD.
What I noticed changing was, instead of
L4TLauncher: Attempting GRUB Boot
L4TLauncher: Attempting Direct Boot
suddenly
was shown/printed to serial console.
And afterwards it was not booting successfully.
However, I now changed the boot order to put the SSD on top, what removed the network connection errors, but kept the rest as described before.
hello pastap,
may I also know what’s the system it is?
Hello @JerryChang,
It is a Jetson Xavier NX module on a JNX30D carrier board from AUVIDEA running Jetpack 5.0.2 / L4T 35.1 / Ubuntu 20.04 (installed with the Nvidia SDK Manager)
hello pastap,
do you have specific flash configuration file?
default Nvidia SDK Manager to flash Xavier NX it’ll flash JetPack release image to internal eMMC (jetson-xavier-nx-devkit-emmc.conf) or SD (jetson-xavier-nx-devkit.conf).
Hello @JerryChang,
I could not find .conf files in the files I got from AUVIDEA to modify/add for installation.
As flashing is already a while ago, I checked the SDK Manager again to be sure.
One can pick NVMe beside the default EMMC/SDcard, like in my screenshot below
That is what I did instead of using a configuration file.
hello pastap,
please confirm the flash process has completed, but boot hang at UEFI?
please setup serial console to gather bootloader logs for reference, thanks
Hello @JerryChang,
I am afraid there is a misunderstanding.
I was hoping that I do not have to flash and can recover my previous installation.
So it was flashing, booting and running already for more than a month successfully until the boot mode changed as described above.
The previous logs are from the serial console/bootloader output.
Afterwards there is no more output (I have disabled nvgetty) and on screen I can only see a blinking cursor in the top left corner.
hello pastap,
it’s hard to distinguish the issue without failure messages.
so… what exactly the content of this SSD.
Hello @JerryChang,
Sorry, I found my mistake.
I was not using the debug UART. I used instead the UART on the GPIO header.
That is the reason for the little and not detailed “logs”.
The debug serial on this board is only accessible via a connector, I currently do not have, but I will provide the bootloader logs when I got it.
