I used a mipi pattern generator (Introspect SV3C) to test the mipi rx function of the Jetson AGX Orin.
Using v4l2cuda (nvidia sample code) to capture image, and pattern generator use vertical colorbar as image pattern for testing.
In Jetson AGX Orin, effective resolution is 3864 * 2192 of device tree and driver.
Pattern resolution of the mipi pattern generator must be greater than effective resolution, min. pattern resolution must (3864+4) * 2192 or 3864 * (2192+2) for this can capture 20 frame.
If pattern resolution equal 3864 * 2192, the result always capture success in first image, timeout in second image.
I would like to confirm if this is the correct result and the reason for it, and if not, how to set it so that the effective resolution can be used to capture the image.
Suppose the real output size is different with the effective size.
Jetson device receive the real size otherwise would failed.
What I want to ask is why does the mipi pattern generator have to be larger than the setting (3864*2192) in the device when output pattern?
As you said, even if the mipi pattern generator gives me an image size larger than the size by the device, it will success capture the frame, for this test result is same, it success capture for continually multi-frame.
So if the mipi pattern generator gives me an image size equal to the size by the device, it also will success capture the frame, and it success capture for continually multi-frame.
But in the current situation, when mipi pattern generator give the image size equal to the size by the device, the only first frame is success capture, but the second frame is happen timed out.
I would like to know why this happens and how to improve it?
Thank.
Get the trace log to check why failed at second frame.
Hi ShaneCCC:
For trace log:
sudo cat /sys/kernel/debug/tracing/trace
# tracer: nop
# entries-in-buffer/entries-written: 370/370 #P:12
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
capture-cuda-4024 [008] .... 360.264324: tegra_channel_open: vi-output, imx415 2-001a
capture-cuda-4024 [008] .... 360.432585: tegra_channel_set_power: imx415 2-001a : 0x1
capture-cuda-4024 [008] .... 360.432599: camera_common_s_power: status : 0x1
capture-cuda-4024 [008] .... 360.456734: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x1
capture-cuda-4024 [008] .... 360.456736: csi_s_power: enable : 0x1
capture-cuda-4024 [008] .... 360.457654: tegra_channel_capture_setup: vnc_id 0 W 4640 H 3488 fmt c4
kworker/1:4-631 [001] .... 360.462557: rtcpu_string: tstamp:11994198602 id:0x04010000 str:"VM0 activating."
capture-cuda-4024 [009] .... 360.466731: tegra_channel_set_stream: enable : 0x1
capture-cuda-4024 [009] .... 360.484662: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x1
capture-cuda-4024 [009] .... 360.484664: csi_s_stream: enable : 0x1
capture-cuda-4024 [009] .... 360.485945: tegra_channel_set_stream: imx415 2-001a : 0x1
kworker/1:4-631 [001] .... 360.522548: rtcpu_vinotify_event: tstamp:11994827787 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:383818753792 data:0x399d580010000000
kworker/1:4-631 [001] .... 360.522549: rtcpu_vinotify_event: tstamp:11994827961 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:383818760256 data:0x0000000031000001
kworker/1:4-631 [001] .... 360.522549: rtcpu_vinotify_event: tstamp:11994828158 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:383818810592 data:0x399d550010000000
kworker/1:4-631 [001] .... 360.522550: rtcpu_vinotify_event: tstamp:11994828324 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:383818817120 data:0x0000000031000002
kworker/1:4-631 [001] .... 360.522551: rtcpu_nvcsi_intr: tstamp:11994904972 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
kworker/1:4-631 [001] .... 360.522551: rtcpu_nvcsi_intr: tstamp:11994904972 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000110
kworker/1:4-631 [001] .... 360.522552: rtcpu_nvcsi_intr: tstamp:11994907349 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
kworker/1:4-631 [001] .... 360.522552: rtcpu_nvcsi_intr: tstamp:11994909407 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
kworker/1:4-631 [001] .... 360.522552: rtcpu_nvcsi_intr: tstamp:11994911457 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
kworker/1:4-631 [001] .... 360.522552: rtcpu_nvcsi_intr: tstamp:11994913503 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
kworker/1:4-631 [001] .... 360.522552: rtcpu_nvcsi_intr: tstamp:11994917341 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
kworker/1:4-631 [001] .... 360.522552: rtcpu_nvcsi_intr: tstamp:11994917341 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000110
kworker/1:4-631 [001] .... 360.522553: rtcpu_nvcsi_intr: tstamp:11994919682 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
kworker/1:4-631 [001] .... 360.522553: rtcpu_nvcsi_intr: tstamp:11994919682 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000110
kworker/1:4-631 [001] .... 360.522553: rtcpu_nvcsi_intr: tstamp:11994922039 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
kworker/1:4-631 [001] .... 360.522553: rtcpu_nvcsi_intr: tstamp:11994922039 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000110
kworker/1:4-631 [001] .... 360.522554: rtcpu_vinotify_error: tstamp:11994925197 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:383837248736 data:0x0000000000000001
kworker/1:4-631 [001] .... 360.522554: rtcpu_nvcsi_intr: tstamp:11994925863 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
kworker/1:4-631 [001] .... 360.522554: rtcpu_nvcsi_intr: tstamp:11994927914 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
kworker/1:4-631 [001] .... 360.522554: rtcpu_nvcsi_intr: tstamp:11994929980 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000010
kworker/1:4-631 [001] .... 360.522555: rtcpu_nvcsi_intr: tstamp:11994930373 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000010
kworker/1:4-631 [001] .... 360.522555: rtcpu_nvcsi_intr: tstamp:11994932615 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
kworker/1:4-631 [001] .... 360.522555: rtcpu_nvcsi_intr: tstamp:11994932615 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000110
kworker/1:4-631 [001] .... 360.522555: rtcpu_vinotify_event: tstamp:11995370237 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:383837248736 data:0x0000000000000001
kworker/1:4-631 [001] .... 360.522555: rtcpu_vinotify_event: tstamp:11995370374 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:383847860352 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.522556: rtcpu_vinotify_event: tstamp:11995370530 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:383847860448 data:0x0000000800000000
kworker/1:4-631 [001] .... 360.522556: rtcpu_vinotify_event: tstamp:11995370666 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:383847861056 data:0x0000000000000001
kworker/1:4-631 [001] .... 360.522556: rtcpu_vinotify_event: tstamp:11995370818 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:383847902336 data:0x0000000008020001
kworker/1:4-631 [001] .... 360.578560: rtcpu_vinotify_event: tstamp:11996291299 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:383880689184 data:0x000000000d9f0002
kworker/1:4-631 [001] .... 360.578563: rtcpu_vinotify_event: tstamp:11996291453 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:383880689760 data:0x0000000000000020
kworker/1:4-631 [001] .... 360.578563: rtcpu_vinotify_event: tstamp:11996291588 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:383880689792 data:0x0000200000000000
kworker/1:4-631 [001] .... 360.578564: rtcpu_vinotify_event: tstamp:11996291740 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:383880768864 data:0x0000000001020001
kworker/1:4-631 [001] .... 360.578564: rtcpu_vinotify_event: tstamp:11996291877 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:383880689856 data:0x0000000800000000
kworker/1:4-631 [001] .... 360.578565: rtcpu_vinotify_event: tstamp:11996292028 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:383880690144 data:0x0000000000000000
kworker/1:4-631 [001] .... 360.578565: rtcpu_vinotify_event: tstamp:11996292160 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:383881192992 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.578565: rtcpu_vinotify_event: tstamp:11996781091 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:383881193088 data:0x0000000800000000
kworker/1:4-631 [001] .... 360.578566: rtcpu_vinotify_event: tstamp:11996781226 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:383881193664 data:0x0000000000000001
kworker/1:4-631 [001] .... 360.578566: rtcpu_vinotify_event: tstamp:11997323158 cch:0 vi:0 tag:CHANSEL_PXL_EOF channel:0x23 frame:0 vi_tstamp:383914021856 data:0x000000000d9f0002
kworker/1:4-631 [001] .... 360.578567: rtcpu_vinotify_event: tstamp:11997323290 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:383914022432 data:0x0000000000000020
kworker/1:4-631 [001] .... 360.578567: rtcpu_vinotify_event: tstamp:11997323444 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:383914022432 data:0x0000200000000000
kworker/1:4-631 [001] .... 360.578567: rtcpu_vinotify_event: tstamp:11997323578 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:383914022528 data:0x0000000800000000
kworker/1:4-631 [001] .... 360.578568: rtcpu_vinotify_event: tstamp:11997323730 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:383914022816 data:0x0000000000000000
kworker/1:4-631 [001] .... 360.578569: rtcpu_vinotify_error: tstamp:11997333067 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:383914526336 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.634544: rtcpu_vinotify_event: tstamp:11997865746 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:383914525664 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.634545: rtcpu_vinotify_event: tstamp:11997865903 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:383914526336 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.634546: rtcpu_vinotify_error: tstamp:11998374701 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:383947858976 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.634546: rtcpu_vinotify_event: tstamp:11998408603 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:383947355072 data:0x0000000000000020
kworker/1:4-631 [001] .... 360.634546: rtcpu_vinotify_event: tstamp:11998408752 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:383947858272 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.634547: rtcpu_vinotify_event: tstamp:11998408886 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:383947858976 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.634547: rtcpu_vinotify_error: tstamp:11999416348 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:383981191616 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.634548: rtcpu_vinotify_event: tstamp:11999493311 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:383980687744 data:0x0000000000000020
kworker/1:4-631 [001] .... 360.634548: rtcpu_vinotify_event: tstamp:11999493446 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:383981190944 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.634549: rtcpu_vinotify_event: tstamp:11999493599 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:383981191616 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.690722: rtcpu_vinotify_event: tstamp:12000441052 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384014020352 data:0x0000000000000020
kworker/1:4-631 [001] .... 360.690725: rtcpu_vinotify_error: tstamp:12000457991 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384014524256 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.690726: rtcpu_vinotify_event: tstamp:12000959015 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384014523584 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.690726: rtcpu_vinotify_event: tstamp:12000959150 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384014524256 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.746577: rtcpu_vinotify_error: tstamp:12001499766 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384047856896 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.746580: rtcpu_vinotify_event: tstamp:12001504102 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384047353024 data:0x0000000000000020
kworker/1:4-631 [001] .... 360.746580: rtcpu_vinotify_event: tstamp:12001504233 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384047856224 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.746581: rtcpu_vinotify_event: tstamp:12001504384 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384047856896 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.746582: rtcpu_vinotify_error: tstamp:12002541288 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384081189568 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.746582: rtcpu_vinotify_event: tstamp:12002586588 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384080685664 data:0x0000000000000020
kworker/1:4-631 [001] .... 360.746583: rtcpu_vinotify_event: tstamp:12002586740 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384081188896 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.746583: rtcpu_vinotify_event: tstamp:12002586872 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384081189568 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.802543: rtcpu_vinotify_error: tstamp:12003582929 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384114522208 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.802543: rtcpu_vinotify_event: tstamp:12003671299 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384114018304 data:0x0000000000000020
kworker/1:4-631 [001] .... 360.802544: rtcpu_vinotify_event: tstamp:12003671431 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384114521536 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.802544: rtcpu_vinotify_event: tstamp:12003671581 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384114522208 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.802544: rtcpu_vinotify_error: tstamp:12004624572 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384147854880 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.802544: rtcpu_vinotify_event: tstamp:12004756004 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384147350976 data:0x0000000000000020
kworker/1:4-631 [001] .... 360.802544: rtcpu_vinotify_event: tstamp:12004756155 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384147854176 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.802544: rtcpu_vinotify_event: tstamp:12004756285 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384147854880 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.858701: rtcpu_vinotify_error: tstamp:12005666540 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384181187488 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.858704: rtcpu_vinotify_event: tstamp:12005667118 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384180683584 data:0x0000000000000020
kworker/1:4-631 [001] .... 360.858704: rtcpu_vinotify_event: tstamp:12005667251 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384181186816 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.858705: rtcpu_vinotify_event: tstamp:12006167270 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384181187488 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.914563: rtcpu_vinotify_error: tstamp:12006707992 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384214520160 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.914566: rtcpu_vinotify_event: tstamp:12006712361 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384214016256 data:0x0000000000000020
kworker/1:4-631 [001] .... 360.914567: rtcpu_vinotify_event: tstamp:12006712511 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384214519488 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.914567: rtcpu_vinotify_event: tstamp:12006712642 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384214520160 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.914568: rtcpu_vinotify_error: tstamp:12007749508 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384247852800 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.914570: rtcpu_vinotify_event: tstamp:12007794840 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384247348896 data:0x0000000000000020
kworker/1:4-631 [001] .... 360.914570: rtcpu_vinotify_event: tstamp:12007794972 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384247852096 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.914571: rtcpu_vinotify_event: tstamp:12007795125 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384247852800 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.970546: rtcpu_vinotify_error: tstamp:12008791152 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384281185472 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.970547: rtcpu_vinotify_event: tstamp:12008879547 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384280681568 data:0x0000000000000020
kworker/1:4-631 [001] .... 360.970547: rtcpu_vinotify_event: tstamp:12008879697 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384281184768 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.970548: rtcpu_vinotify_event: tstamp:12008879828 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384281185472 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.970548: rtcpu_vinotify_error: tstamp:12009832798 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384314518112 data:0x0000000000000569
kworker/1:4-631 [001] .... 360.970549: rtcpu_vinotify_event: tstamp:12009965374 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384314014208 data:0x0000000000000020
kworker/1:4-631 [001] .... 360.970549: rtcpu_vinotify_event: tstamp:12009965505 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384314517408 data:0x0000000000000010
kworker/1:4-631 [001] .... 360.970549: rtcpu_vinotify_event: tstamp:12009965657 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384314518112 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.026706: rtcpu_vinotify_error: tstamp:12010874769 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384347850752 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.026708: rtcpu_vinotify_event: tstamp:12010875346 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384347346848 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.026709: rtcpu_vinotify_event: tstamp:12010875496 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384347850080 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.026709: rtcpu_vinotify_event: tstamp:12010875627 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384347850752 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.082707: rtcpu_vinotify_error: tstamp:12011916220 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384381183424 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.082710: rtcpu_vinotify_event: tstamp:12011920351 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384380679520 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.082710: rtcpu_vinotify_event: tstamp:12011920481 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384381182720 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.082711: rtcpu_vinotify_event: tstamp:12011920632 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384381183424 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.082711: rtcpu_vinotify_error: tstamp:12012957733 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384414516032 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.082712: rtcpu_vinotify_event: tstamp:12013002830 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384414012160 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.082713: rtcpu_vinotify_event: tstamp:12013002982 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384414515360 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.082713: rtcpu_vinotify_event: tstamp:12013003112 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384414516032 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.138703: rtcpu_vinotify_error: tstamp:12013999377 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384447848704 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.138706: rtcpu_vinotify_event: tstamp:12014088664 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384447344800 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.138706: rtcpu_vinotify_event: tstamp:12014088796 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384447848032 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.138707: rtcpu_vinotify_event: tstamp:12014088948 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384447848704 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.138707: rtcpu_vinotify_error: tstamp:12015041024 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384481181344 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.138708: rtcpu_vinotify_event: tstamp:12015173363 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384480677440 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.138709: rtcpu_vinotify_event: tstamp:12015173514 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384481180672 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.138709: rtcpu_vinotify_event: tstamp:12015173646 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384481181344 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.194551: rtcpu_vinotify_error: tstamp:12016082669 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384514513984 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.194554: rtcpu_vinotify_event: tstamp:12016258066 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384514010112 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.194555: rtcpu_vinotify_event: tstamp:12016258197 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384514513312 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.194555: rtcpu_vinotify_event: tstamp:12016258350 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384514513984 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.250702: rtcpu_vinotify_event: tstamp:12017107341 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384547342720 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.250705: rtcpu_vinotify_error: tstamp:12017124443 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384547846656 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.250706: rtcpu_vinotify_event: tstamp:12017614416 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384547845952 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.250706: rtcpu_vinotify_event: tstamp:12017614547 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384547846656 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.250707: rtcpu_vinotify_event: tstamp:12018157654 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384580675392 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.250708: rtcpu_vinotify_error: tstamp:12018165960 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384581179296 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.250708: rtcpu_vinotify_event: tstamp:12018700237 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384581178624 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.250709: rtcpu_vinotify_event: tstamp:12018700387 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384581179296 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.306550: rtcpu_vinotify_error: tstamp:12019207607 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384614511936 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.306553: rtcpu_vinotify_event: tstamp:12019241986 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384614008032 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.306554: rtcpu_vinotify_event: tstamp:12019242138 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384614511264 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.306555: rtcpu_vinotify_event: tstamp:12019242269 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384614511936 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.306556: rtcpu_vinotify_error: tstamp:12020249250 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384647844576 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.306556: rtcpu_vinotify_event: tstamp:12020327808 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384647340672 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.306557: rtcpu_vinotify_event: tstamp:12020327940 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384647843904 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.306557: rtcpu_vinotify_event: tstamp:12020328096 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384647844576 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.362701: rtcpu_vinotify_error: tstamp:12021290896 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384681177248 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.362704: rtcpu_vinotify_event: tstamp:12021412523 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384680673344 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.362704: rtcpu_vinotify_event: tstamp:12021412673 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384681176576 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.362705: rtcpu_vinotify_event: tstamp:12021412804 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384681177248 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.362705: rtcpu_vinotify_error: tstamp:12022332956 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384714509888 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.362706: rtcpu_vinotify_event: tstamp:12022333537 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384714005984 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.362707: rtcpu_vinotify_event: tstamp:12022333669 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384714509184 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.418536: rtcpu_vinotify_event: tstamp:12022822619 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384714509888 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.418537: rtcpu_vinotify_event: tstamp:12023365855 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384747338624 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.418538: rtcpu_vinotify_error: tstamp:12023374192 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384747842528 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.418538: rtcpu_vinotify_event: tstamp:12023908437 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384747841856 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.418538: rtcpu_vinotify_event: tstamp:12023908568 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384747842528 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.474550: rtcpu_vinotify_error: tstamp:12024415832 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384781175168 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.474554: rtcpu_vinotify_event: tstamp:12024450182 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384780671296 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.474554: rtcpu_vinotify_event: tstamp:12024450313 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384781174464 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.474555: rtcpu_vinotify_event: tstamp:12024450466 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384781175168 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.474556: rtcpu_vinotify_error: tstamp:12025457502 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384814507840 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.474556: rtcpu_vinotify_event: tstamp:12025536011 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384814003936 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.474557: rtcpu_vinotify_event: tstamp:12025536160 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384814507168 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.474558: rtcpu_vinotify_event: tstamp:12025536288 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384814507840 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.530700: rtcpu_vinotify_error: tstamp:12026499122 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384847840480 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.530703: rtcpu_vinotify_event: tstamp:12026620727 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384847336576 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.530703: rtcpu_vinotify_event: tstamp:12026620859 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384847839776 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.530704: rtcpu_vinotify_event: tstamp:12026621014 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384847840480 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.530705: rtcpu_vinotify_error: tstamp:12027541183 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384881173120 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.530705: rtcpu_vinotify_event: tstamp:12027541759 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384880669248 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.530706: rtcpu_vinotify_event: tstamp:12027541911 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384881172448 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.530708: rtcpu_vinotify_event: tstamp:12027542043 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384881173120 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.586543: rtcpu_vinotify_event: tstamp:12028573792 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384914001888 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.586546: rtcpu_vinotify_error: tstamp:12028582439 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384914505792 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.586547: rtcpu_vinotify_event: tstamp:12029116375 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384914505120 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.586547: rtcpu_vinotify_event: tstamp:12029116527 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384914505792 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.642691: rtcpu_vinotify_error: tstamp:12029624058 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384947838432 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.642694: rtcpu_vinotify_event: tstamp:12029659234 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384947334528 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.642695: rtcpu_vinotify_event: tstamp:12029659386 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384947837728 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.642695: rtcpu_vinotify_event: tstamp:12029659517 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384947838432 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.642696: rtcpu_vinotify_error: tstamp:12030665702 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384981171072 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.642696: rtcpu_vinotify_event: tstamp:12030743954 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:384980667168 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.642697: rtcpu_vinotify_event: tstamp:12030744088 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:384981170400 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.642698: rtcpu_vinotify_event: tstamp:12030744241 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:384981171072 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.698533: rtcpu_vinotify_error: tstamp:12031707383 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385014503712 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.698534: rtcpu_vinotify_event: tstamp:12031828655 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385013999808 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.698535: rtcpu_vinotify_event: tstamp:12031828809 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385014503040 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.698536: rtcpu_vinotify_event: tstamp:12031828941 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385014503712 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.698536: rtcpu_vinotify_error: tstamp:12032749124 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385047836384 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.754546: rtcpu_vinotify_event: tstamp:12032914472 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385047332480 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.754548: rtcpu_vinotify_event: tstamp:12032914604 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385047835680 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.754548: rtcpu_vinotify_event: tstamp:12032914757 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385047836384 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.754549: rtcpu_vinotify_event: tstamp:12033773665 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385080665120 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.754551: rtcpu_vinotify_error: tstamp:12033790636 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385081169024 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.754551: rtcpu_vinotify_event: tstamp:12034270823 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385081168320 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.754552: rtcpu_vinotify_event: tstamp:12034270955 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385081169024 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.810538: rtcpu_vinotify_error: tstamp:12034832309 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385114501664 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.810541: rtcpu_vinotify_event: tstamp:12035355510 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385113997760 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.810541: rtcpu_vinotify_event: tstamp:12035355645 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385114500992 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.810541: rtcpu_vinotify_event: tstamp:12035355798 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385114501664 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.810542: rtcpu_vinotify_error: tstamp:12035873931 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385147834336 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.810542: rtcpu_vinotify_event: tstamp:12035898368 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385147330432 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.810542: rtcpu_vinotify_event: tstamp:12035898521 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385147833632 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.810543: rtcpu_vinotify_event: tstamp:12035898655 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385147834336 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.866694: rtcpu_vinotify_error: tstamp:12036915575 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385181166976 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.866697: rtcpu_vinotify_event: tstamp:12036983078 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385180663072 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.866698: rtcpu_vinotify_event: tstamp:12036983211 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385181166272 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.866698: rtcpu_vinotify_event: tstamp:12036983368 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385181166976 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.866699: rtcpu_vinotify_error: tstamp:12037957349 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385214499616 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.866699: rtcpu_vinotify_event: tstamp:12038068900 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385213995744 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.866700: rtcpu_vinotify_event: tstamp:12038069054 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385214498944 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.866701: rtcpu_vinotify_event: tstamp:12038069189 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385214499616 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.922530: rtcpu_vinotify_error: tstamp:12038999189 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385247832256 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.922530: rtcpu_vinotify_event: tstamp:12038999771 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385247328352 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.922531: rtcpu_vinotify_event: tstamp:12038999902 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385247831584 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.922531: rtcpu_vinotify_event: tstamp:12039533752 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385247832256 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.978692: rtcpu_vinotify_error: tstamp:12040040513 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385281164928 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.978695: rtcpu_vinotify_event: tstamp:12040075499 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385280661024 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.978696: rtcpu_vinotify_event: tstamp:12040075652 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385281164224 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.978696: rtcpu_vinotify_event: tstamp:12040075784 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385281164928 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.978697: rtcpu_vinotify_error: tstamp:12041082183 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385314497568 data:0x0000000000000569
kworker/1:4-631 [001] .... 361.978697: rtcpu_vinotify_event: tstamp:12041161320 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385313993664 data:0x0000000000000020
kworker/1:4-631 [001] .... 361.978698: rtcpu_vinotify_event: tstamp:12041161453 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385314496864 data:0x0000000000000010
kworker/1:4-631 [001] .... 361.978698: rtcpu_vinotify_event: tstamp:12041161606 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385314497568 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.034683: rtcpu_vinotify_error: tstamp:12042123801 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385347830208 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.034686: rtcpu_vinotify_event: tstamp:12042246034 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385347326304 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.034686: rtcpu_vinotify_event: tstamp:12042246189 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385347829536 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.034687: rtcpu_vinotify_event: tstamp:12042246322 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385347830208 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.034687: rtcpu_vinotify_error: tstamp:12043165575 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385381162880 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.034688: rtcpu_vinotify_event: tstamp:12043330762 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385380658944 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.034688: rtcpu_vinotify_event: tstamp:12043330896 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385381162176 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.034689: rtcpu_vinotify_event: tstamp:12043331051 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385381162880 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.090549: rtcpu_vinotify_error: tstamp:12044207419 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385414495488 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.090552: rtcpu_vinotify_event: tstamp:12044207996 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385413991616 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.090553: rtcpu_vinotify_event: tstamp:12044208149 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385414494816 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.090554: rtcpu_vinotify_event: tstamp:12044208281 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385414495488 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.146530: rtcpu_vinotify_error: tstamp:12045248739 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385447828160 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.146531: rtcpu_vinotify_event: tstamp:12045284616 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385447324256 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.146532: rtcpu_vinotify_event: tstamp:12045284749 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385447827488 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.146532: rtcpu_vinotify_event: tstamp:12045284907 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385447828160 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.146533: rtcpu_vinotify_error: tstamp:12046290383 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385481160768 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.146534: rtcpu_vinotify_event: tstamp:12046369315 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385480656896 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.146534: rtcpu_vinotify_event: tstamp:12046369469 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385481160096 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.146535: rtcpu_vinotify_event: tstamp:12046369603 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385481160768 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.202549: rtcpu_vinotify_error: tstamp:12047332055 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385514493440 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.202553: rtcpu_vinotify_event: tstamp:12047454028 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385513989568 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.202553: rtcpu_vinotify_event: tstamp:12047454163 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385514492768 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.202554: rtcpu_vinotify_event: tstamp:12047454317 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385514493440 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.202555: rtcpu_vinotify_error: tstamp:12048373804 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385547826080 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.202556: rtcpu_vinotify_event: tstamp:12048539845 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385547322176 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.202557: rtcpu_vinotify_event: tstamp:12048540002 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385547825408 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.202558: rtcpu_vinotify_event: tstamp:12048540134 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385547826080 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.258699: rtcpu_vinotify_error: tstamp:12049415321 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385581158752 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.258702: rtcpu_vinotify_event: tstamp:12049624561 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385580654880 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.258703: rtcpu_vinotify_event: tstamp:12049624696 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385581158048 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.258703: rtcpu_vinotify_event: tstamp:12049624849 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385581158752 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.314547: rtcpu_vinotify_event: tstamp:12050439990 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385613987488 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.314551: rtcpu_vinotify_error: tstamp:12050456987 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385614491392 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.314552: rtcpu_vinotify_event: tstamp:12050980912 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385614490688 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.314552: rtcpu_vinotify_event: tstamp:12050981047 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385614491392 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.314553: rtcpu_vinotify_error: tstamp:12051498608 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385647824032 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.314553: rtcpu_vinotify_event: tstamp:12051523778 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385647320160 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.314554: rtcpu_vinotify_event: tstamp:12051523909 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385647823360 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.314554: rtcpu_vinotify_event: tstamp:12051524063 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385647824032 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.370695: rtcpu_vinotify_error: tstamp:12052540255 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385681156704 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.370698: rtcpu_vinotify_event: tstamp:12052608486 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385680652800 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.370699: rtcpu_vinotify_event: tstamp:12052608641 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385681156000 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.370699: rtcpu_vinotify_event: tstamp:12052608774 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385681156704 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.370700: rtcpu_vinotify_error: tstamp:12053582064 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385714489344 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.370700: rtcpu_vinotify_event: tstamp:12053693189 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385713985440 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.370701: rtcpu_vinotify_event: tstamp:12053693323 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385714488640 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.370701: rtcpu_vinotify_event: tstamp:12053693476 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385714489344 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.426546: rtcpu_vinotify_error: tstamp:12054623546 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385747821984 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.426549: rtcpu_vinotify_event: tstamp:12054779015 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385747318112 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.426550: rtcpu_vinotify_event: tstamp:12054779171 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385747821312 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.426551: rtcpu_vinotify_event: tstamp:12054779303 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385747821984 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.486531: rtcpu_vinotify_error: tstamp:12055665514 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385781154624 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.486533: rtcpu_vinotify_event: tstamp:12055666099 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385780650720 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.486534: rtcpu_vinotify_event: tstamp:12055666234 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385781153952 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.486534: rtcpu_vinotify_event: tstamp:12056189163 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385781154624 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.486535: rtcpu_vinotify_error: tstamp:12056706860 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385814487296 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.486535: rtcpu_vinotify_event: tstamp:12056732021 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385813983392 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.486536: rtcpu_vinotify_event: tstamp:12056732177 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385814486592 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.486536: rtcpu_vinotify_event: tstamp:12056732310 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385814487296 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.542540: rtcpu_vinotify_error: tstamp:12057748481 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385847819936 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.542543: rtcpu_vinotify_event: tstamp:12057816731 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385847316032 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.542544: rtcpu_vinotify_event: tstamp:12057816865 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385847819232 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.542544: rtcpu_vinotify_event: tstamp:12057817025 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385847819936 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.542545: rtcpu_vinotify_error: tstamp:12058790125 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385881152576 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.542545: rtcpu_vinotify_event: tstamp:12058901439 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385880648672 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.542546: rtcpu_vinotify_event: tstamp:12058901592 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385881151904 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.542546: rtcpu_vinotify_event: tstamp:12058901728 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385881152576 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.598526: rtcpu_vinotify_error: tstamp:12059831798 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385914485248 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.598529: rtcpu_vinotify_event: tstamp:12059987270 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385913981344 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.598529: rtcpu_vinotify_event: tstamp:12059987402 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385914484544 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.598530: rtcpu_vinotify_event: tstamp:12059987555 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385914485248 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.598530: rtcpu_vinotify_error: tstamp:12060873743 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385947817888 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.598530: rtcpu_vinotify_event: tstamp:12060874320 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385947313952 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.598531: rtcpu_vinotify_event: tstamp:12060874472 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385947817184 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.598531: rtcpu_vinotify_event: tstamp:12060874603 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385947817888 data:0x0000000000000569
capture-cuda-4026 [000] .... 362.609529: tegra_channel_close: vi-output, imx415 2-001a
kworker/1:4-631 [001] .... 362.654521: rtcpu_vinotify_error: tstamp:12061915077 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385981150528 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.654522: rtcpu_vinotify_event: tstamp:12061940012 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:385980646656 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.654522: rtcpu_vinotify_event: tstamp:12061940145 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:385981149856 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.654523: rtcpu_vinotify_event: tstamp:12061940302 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:385981150528 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.710529: rtcpu_vinotify_error: tstamp:12062956733 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386014483168 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.710531: rtcpu_vinotify_event: tstamp:12063024725 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:386013979264 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.710532: rtcpu_vinotify_event: tstamp:12063024879 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:386014482496 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.710532: rtcpu_vinotify_event: tstamp:12063025011 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386014483168 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.710533: rtcpu_vinotify_error: tstamp:12063998351 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386047815840 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.710533: rtcpu_vinotify_event: tstamp:12064110556 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:386047311936 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.710534: rtcpu_vinotify_event: tstamp:12064110688 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:386047815168 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.710534: rtcpu_vinotify_event: tstamp:12064110842 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386047815840 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.766517: rtcpu_vinotify_error: tstamp:12065039998 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386081148480 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.766517: rtcpu_vinotify_event: tstamp:12065195252 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:386080644576 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.766518: rtcpu_vinotify_event: tstamp:12065195405 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:386081147776 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.766518: rtcpu_vinotify_event: tstamp:12065195539 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386081148480 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.766518: rtcpu_vinotify_error: tstamp:12066081671 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386114481120 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.826516: rtcpu_vinotify_event: tstamp:12066279963 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:386113977216 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.826516: rtcpu_vinotify_event: tstamp:12066280102 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:386114480448 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.826517: rtcpu_vinotify_event: tstamp:12066280256 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386114481120 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.826517: rtcpu_vinotify_event: tstamp:12067106314 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:386147309856 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.826518: rtcpu_vinotify_error: tstamp:12067123285 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386147813760 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.826518: rtcpu_vinotify_event: tstamp:12067636313 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:386147813088 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.826519: rtcpu_vinotify_event: tstamp:12067636445 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386147813760 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.882682: rtcpu_vinotify_error: tstamp:12068164935 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386181146400 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.882685: rtcpu_vinotify_event: tstamp:12068179176 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:386180642528 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.882686: rtcpu_vinotify_event: tstamp:12068179308 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:386181145728 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.882687: rtcpu_vinotify_event: tstamp:12068179459 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386181146400 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.882688: rtcpu_vinotify_error: tstamp:12069206606 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386214479072 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.882688: rtcpu_vinotify_event: tstamp:12069264994 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:386213975168 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.882689: rtcpu_vinotify_event: tstamp:12069265145 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:386214478400 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.882690: rtcpu_vinotify_event: tstamp:12069265274 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386214479072 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.938538: rtcpu_vinotify_error: tstamp:12070248223 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386247811712 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.938540: rtcpu_vinotify_event: tstamp:12070349709 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:386247307808 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.938541: rtcpu_vinotify_event: tstamp:12070349841 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:386247811008 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.938541: rtcpu_vinotify_event: tstamp:12070349994 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386247811712 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.938542: rtcpu_vinotify_error: tstamp:12071289867 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386281144352 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.938543: rtcpu_vinotify_event: tstamp:12071434424 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:386280640448 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.938543: rtcpu_vinotify_event: tstamp:12071434578 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:386281143680 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.938544: rtcpu_vinotify_event: tstamp:12071434709 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386281144352 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.994678: rtcpu_vinotify_error: tstamp:12072331837 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386314476992 data:0x0000000000000569
kworker/1:4-631 [001] .... 362.994681: rtcpu_vinotify_event: tstamp:12072332415 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:386313973088 data:0x0000000000000020
kworker/1:4-631 [001] .... 362.994682: rtcpu_vinotify_event: tstamp:12072332546 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:386314476320 data:0x0000000000000010
kworker/1:4-631 [001] .... 362.994682: rtcpu_vinotify_event: tstamp:12072845693 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386314476992 data:0x0000000000000569
kworker/1:4-631 [001] .... 363.050671: rtcpu_vinotify_error: tstamp:12073373158 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386347809664 data:0x0000000000000569
kworker/1:4-631 [001] .... 363.050674: rtcpu_vinotify_event: tstamp:12073387441 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:386347305760 data:0x0000000000000020
kworker/1:4-631 [001] .... 363.050675: rtcpu_vinotify_event: tstamp:12073387592 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:386347808992 data:0x0000000000000010
kworker/1:4-631 [001] .... 363.050675: rtcpu_vinotify_event: tstamp:12073387725 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386347809664 data:0x0000000000000569
kworker/1:4-631 [001] .... 363.050675: rtcpu_vinotify_error: tstamp:12074414805 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386381142304 data:0x0000000000000569
kworker/1:4-631 [001] .... 363.050676: rtcpu_vinotify_event: tstamp:12074473258 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:386380638400 data:0x0000000000000020
kworker/1:4-631 [001] .... 363.050676: rtcpu_vinotify_event: tstamp:12074473390 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:386381141600 data:0x0000000000000010
kworker/1:4-631 [001] .... 363.050677: rtcpu_vinotify_event: tstamp:12074473545 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386381142304 data:0x0000000000000569
kworker/1:4-631 [001] .... 363.106518: rtcpu_vinotify_error: tstamp:12075456475 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386414474944 data:0x0000000000000569
kworker/1:4-631 [001] .... 363.106522: rtcpu_vinotify_event: tstamp:12075557970 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:386413971040 data:0x0000000000000020
kworker/1:4-631 [001] .... 363.106522: rtcpu_vinotify_event: tstamp:12075558122 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:386414474272 data:0x0000000000000010
kworker/1:4-631 [001] .... 363.106523: rtcpu_vinotify_event: tstamp:12075558253 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:386414474944 data:0x0000000000000569
kworker/1:4-631 [001] .... 363.106523: rtcpu_vinotify_error: tstamp:12075949622 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:386430267072 data:0x0000000000000001
kworker/1:4-631 [001] .... 363.106524: rtcpu_vinotify_event: tstamp:12076100823 cch:-1 vi:0 tag:CSIMUX_STREAM channel:0x00 frame:0 vi_tstamp:386430267072 data:0x0000000000000001
kworker/1:4-631 [001] .... 363.106524: rtcpu_vinotify_event: tstamp:12076100956 cch:-1 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:386430267072 data:0x0000000000000020
vi-output, imx4-4028 [003] .... 363.129885: tegra_channel_capture_setup: vnc_id 0 W 4640 H 3488 fmt c4
capture-cuda-4026 [001] .... 363.139480: tegra_channel_set_stream: enable : 0x0
capture-cuda-4026 [001] .... 363.139482: tegra_channel_set_stream: imx415 2-001a : 0x0
capture-cuda-4026 [001] .... 363.139488: tegra_channel_set_stream: 13e40000.host1x:nvcsi@15a00000- : 0x0
capture-cuda-4026 [001] .... 363.139489: csi_s_stream: enable : 0x0
capture-cuda-4026 [001] .... 363.154679: tegra_channel_set_power: imx415 2-001a : 0x0
capture-cuda-4026 [001] .... 363.154686: camera_common_s_power: status : 0x0
capture-cuda-4026 [001] .... 363.154959: tegra_channel_set_power: 13e40000.host1x:nvcsi@15a00000- : 0x0
capture-cuda-4026 [001] .... 363.154961: csi_s_power: enable : 0x0
kworker/1:4-631 [001] .... 368.738644: rtcpu_string: tstamp:12251327719 id:0x04010000 str:"VM0 deactivating."
For dmesg log:
[ 360.485951] mode = 0
[ 360.528963] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 262144
[ 363.058680] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 363.068598] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 363.093132] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 363.100856] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=0, csi_port=0
[ 363.111524] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 363.119234] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 0 vc- 0
[ 363.129979] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
Please help solve this problem, thank
The CHANSEL_SHORT_FRAME tell the output lines less than driver expected.
Hi ShaneCCC:
Thank you for your reply.
I found the problem, I had previously set embedded_metadata_height to 1 and that’s what caused the problem.
When I add one row data and header of embedded data in pattern for mipi pattern generator, I can use the effective size to collect images continuously.
Of course I also change embedded_metadata_height to 0 in device tree for testing, the pattern not has embedded data for mipi pattern generator, the result as same, effective size to collect images continuously.
system
Closed
November 20, 2023, 5:24am
10
