Hi, all.
I am learning CUDA programming from scratch. The following is a (stupid and simple function) program, But the compiled binary file crashes on execution everytime. I think that is because there are read beyond the limitation of memory. However I cam’t fix the exact problem. Can anyone help me? Thanx.
my program environment:
Winxp with sp3, Vc 9.0( cl.exe version 15.00.21022.08), Geforce GT 9800, Nvidia Driver 266.58
Winxp with sp3, Vc 9.0( cl.exe version 15.00.21022.08), Geforce GT 9800, Nvidia Driver 270.61
Win7, Vc 9.0( cl.exe version 15.00.21022.08), C2050 + Quodra FX3800, Nvidia Driver 270.61
My vc says, sizeof(int)=4 bytes, so I only allocated
655353sizeof(int)=786420=786k=0.8M
in both host and cuda mem. I don’t think 0.8M exceeds the ability of ram
search the number x, where x*x can be splited into 2 parts: head, tail
(head+tail)*(head+tail)=x*x
for example
(20 + 25)*(20 + 25)=45*45=20 25
head=20, tail=25
#include<iostream>
#include<time.h>
#define NUM (65535*2) //if NUM is 65535, the program runs ok
__global__ void kernel(int *dev_num)
int tid=threadIdx.x + blockIdx.x*blockDim.x;
int head, tail, sq;
while (tid<NUM)
sq=tid*tid;
head=sq / 100;
tail=sq % 100;
if ((head+tail)*(head+tail)==sq)
//printf("head=%d, tail=%d", head, tail);
dev_num[3*tid]=sq;
dev_num[3*tid+1]=head;
dev_num[3*tid+2]=tail;
else
dev_num[3*tid]=0;
tid+=blockDim.x*gridDim.x;
int main(void)
cudaEvent_t start, stop;
float elapsedTime;
cudaEventCreate(&start);
cudaEventCreate(&stop);
cudaEventRecord(start, 0);
int num[3*NUM];
int *dev_num;
int i=0;
cudaMalloc((void**)&dev_num, 3*NUM*sizeof(int));
memset(&num, 0, 3*NUM*sizeof(int));
kernel<<<128, 128>>>(dev_num);
cudaMemcpy(num, dev_num, 3*NUM*sizeof(int), cudaMemcpyDeviceToHost);
for (i=0;i<NUM;i++)
if (num[3*i])
printf("(%2d + %2d)^2 = %4d\n", num[3*i+1], num[3*i+2], num[3*i]) ;
cudaEventRecord(stop, 0);
cudaEventSynchronize(stop);
cudaEventElapsedTime(&elapsedTime, start, stop);
printf("Time: %f sec(s)\n", elapsedTime);
cudaEventDestroy(start);
cudaEventDestroy(stop);
cudaFree(dev_num);
