- I got a confusing cuda deadlock problem(I am not sure if it’s a deadlock, my code cannot end running).
- I try to debug it. But when I print the variable “active”, the deadlock just disappeared.
- But when I commented out the printf code, deadlock appeared again. here is the code
// active = true; group is cooperative group
void cg_insert_with_lock(bool active, thread_block_tile<cg_size> group) {
//just a lock variable in global memory, initial value is 'unlock_tag'
uint32_t *bucket_lock_addr = cuckoo_table.bucket_lock[0] + 1;
while(group.any(active == true)){
//here is the problem
//printf("active %d\n", active);
bool lock_success = false;
uint32_t group_mask = group.ballot(active == true && *bucket_lock_addr == unlock_tag);
if(group_mask == 0)
continue;
uint32_t leader = __ffs(group_mask) - 1;
//try to lock
if(group.thread_rank() == leader){
auto result = atomicCAS(bucket_lock_addr, unlock_tag, lock_tag);
if(result == unlock_tag){
lock_success = true;
//lock fail
if(group.all(lock_success == false)){
continue;
//do something
//unlock
atomicExch(bucket_lock_addr, unlock_tag);
active = false;
