I have written a version of k-means with map/reduce logic that doesn’t seem to work as it should,it is not finished yet so don’t worry if it doesn’t look like k-means.
The reduce phaze is written with Thrust and works just like it should (just like the cpu version),but the map stage produces different results in GPU and CPU.
I’m attaching the code file for you to see and help me.
Why do you call [font=“Courier New”]mapFuncGpu()[/font] with [font=“Courier New”]256/NUMBER_OF_ELEMENTS[/font] blocks? That doesn’t seem to make sense to me.
In general, I find your code very hard to read. Use proper indentation, and try to have as much commonality between the CPU and GPU versions as possible. There is no need to name the same (automatic) variables differently in the host and device functions. And you can even use the same [font=“Courier New”]distance()[/font] function on host and device if you write it like this:
I tried to clean up the code to make it more readable,but the output is still the same.Now the map functions are almost identical but still produce different results.
I’m also attaching the data files for anyone who would be kind enought to test them in a reference k-means implementation to determine at least which version of the output is correct.
I can’t compile the kernel you’ve uploaded because of missing include files, but how much different your result is ?
The only real difference I can see is that you use double precision sqrt on cpu on gpu you use single precision sqrtf which has 3ulp error (see the docs). Depending on the data your points may end up in different clusters. To minimize the error you could use equivalent metrics, like abs(a.x-b.x)+abs(a.y-b.y).
Btw, to me it seems that you totally miss the point of __syncthreads(), though in the code above it does not affect the result.
I’d recommend you to debug one particular point and see what exactly happens. Either use nsight debugger, or modify the code to output every intermediate step your kernel does.
I have cleaned up the code even further,tested the reduction code with the map function of the cpu as input and it works exactly like it should,i also added a printf in the gpu version of the map function and it seems that the gpu version also maps the data correctly,i dont know why it is not printed correctly on the screen.
I’m attaching the latest version of my code.
The only extra thing you need to build it is to put the thrust lib folder in the same directory as the .cu file.
I don’t get what do you think is wrong with this code ?
Both cpu and gpu versions work as expected, and return 0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1
Because after the first mapFuncGPU you compare it with not initalized prev_begin (or whatever thrust library initializes it to by default), so the iterations continue (btw the result of this call is the same as you get with matlab)
then you run reduceFuncGPU which rearranges your “data” points so that on the next iteration you get 0,0,0,0,0,0,0,1,1,1,1,1,1,1,1,1 .
then you do one more iteration which doesn’t change anything and the loop finally exits.
And btw - debugging by putting printf all around the code is not what I mean by debugging rather use the real debugger where you can see the values of ALL data you work with.
Hello again,
I’m trying to make my code run faster but i haven’t gotten it to work yet.
My first idea was to use tuple with zip_iterator to avoid doing sort_by_key and reduce_by_key twice.For some weird reason the straight forward approach of using the zip_iterator instead of cendroids_x doesn’t work.
My secong idea was to make a struct to house both the x and y coordinates so that i won’t need to have two seperate arrays.That doesn’t compile as it should.
I posted my question in the thrust mailing list but nobody answered so i’m posting it again here
I’m sorry, but I have no idea what thrust is about and how it is supposed to work.
I’m not a fan of libraries like that in general since to me it seems that it would take you a lot less effort writing your own version of reduceFuncGPU without using thrust.
The project might lead to my university diploma thesis,so the idea is to implement reduce function both using thrust and cudpp and native cuda api and evaluate performance overhead,programming effort and stuff like that.
So i will have to write it both with and without thrust.
Thanks for your interest anyway
Apostolis
Edit:i have gotten the zip iterator to work (finally),what i was doing wrong is i forgot to also zip up the data.
