Why not set the latest tag defaultly in source_sync.sh?
In source_sync.sh, if you run it without -t, you should input TAG or Enter again and again.
On the other hand, if you want to figure out tag names excactly, you should use command git tag -l tegra-l4t* but the repo have not been initialized you cannot get correct output by this command.
So, why not set the latest tag as default? It’s helpful to users who are not familiar with L4T. On the other hand, set -t parameter to git describe --tags $(git rev-list --tags --max-count=1) is not harmful to skilled users.
Thanks for the suggestion. We will check this. May not be able to apply this to Jetpack 4, so please check the tags in release notes. The latest one is tegra-l4t-r32.6.1.
