Why nvidia gpu vectorized mem bandwidth drop a lot after a specific problem size
I’ve tested the mem bandwidth between scalar and vectorized mem copy. And noticed some abnormal phenomenal (see pic 1 and 2).
Experimental env: blocksize=256. code:
// Using vectors data types
__global__
void copy(const float2 * __restrict__ in,
 float2 * __restrict__ out,
 int N)
  auto grid = cg::this_grid();
  int tid = grid.thread_rank();
  int stride = grid.size();
  for (int i = tid; i < N / 2; i += stride) {
  out[i] = in[i];
   // Same as:
   // out[i].x = in[i].x;
   // out[i].y = in[i].y;
I have some questions and need your help.
  1. why for both gpu cards, there’s a bumped bandwidth peak which far more than theoretical peak?
  2. with some experiments, I found that the bumped peak only depends on the problem dim (n) and regardless the stride (i.e. for a100, problem size 2097152, if I use 262144/256 (8-loop), 524288/256 (4-loop), 1048576/256 (2-loop) as the stride respectively, i can also observe 1800GB/s bw for float4, same as 2097152/256 → griddim.x)
Also, except the bumped peak, vectorized mem doesn’t give me obvious benefit compared to scalar mem cpy.
(1) Others cannot reproduce your observation based on a code snippet alone. In particular, one cannot assess the soundness of the measurement methodology, which may well be flawed (e.g. with regard to grid sizing, timing).
(2) According to the TechPowerUp database, the theoretical bandwidth of the A100 SXM4 is 2.04 TB/s. One would expect 85%-90% of that to be observable in a practical “maximum bandwidth” test. The graph shown above does not seem to be in contradiction to this.
For a second opinion, you could try my zcopy.cu program below, which uses a 128-bit vector type to maximize the throughput. Sample output:
C:\Users\Norbert\My Programs>zcopy -d1 -n100000000
CUDA initialization: 0.296 seconds
zcopy: running on device 1 (Quadro P2000)
zcopy: using vectors of 100000000 double2 elements (= 1.600e+09 bytes)
zcopy: using 128 threads per block, 781250 blocks
zcopy: mintime = 26.155 msec; eqv. memory bandwith = 122.35 GB/sec
C:\Users\Norbert\My Programs>zcopy -d0 -n100000000
CUDA initialization: 0.292 seconds
zcopy: running on device 0 (Quadro RTX 4000)
zcopy: mintime = 8.440 msec; eqv. memory bandwith = 379.13 GB/sec
According to the TechPowerUp database, the theoretical bandwidth of the Quadro RTX 4000 is 416 GB/sec and 140 GB/sec for the Quadro P2000. So these achieve 91% and 87% of theoretical, respectively.
#include <stdlib.h>
#include <stdio.h>
#include <math.h>
#define ZCOPY_THREADS  128
#define ZCOPY_DEFLEN   30000000
#define ZCOPY_DEFDEV   0
#define ZCOPY_ITER     10           // as in STREAM benchmark
// Macro to catch CUDA errors in CUDA runtime calls
#define CUDA_SAFE_CALL(call)                                          \
do {        \
    cudaError_t err = call;                                           \
    if (cudaSuccess != err) {                                         \
        fprintf (stderr, "Cuda error in file '%s' in line %i : %s.\n",\
                 __FILE__, __LINE__, cudaGetErrorString(err) );       \
        exit(EXIT_FAILURE);                                           \
} while (0)
// Macro to catch CUDA errors in kernel launches
#define CHECK_LAUNCH_ERROR()                                          \
do {        \
    /* Check synchronous errors, i.e. pre-launch */                   \
    cudaError_t err = cudaGetLastError();                             \
    /* Check asynchronous errors, i.e. kernel failed (ULF) */         \
    err = cudaDeviceSynchronize();                                    \
                 __FILE__, __LINE__, cudaGetErrorString( err) );      \
} while (0)
#if defined(_WIN32)
#if !defined(WIN32_LEAN_AND_MEAN)
#define WIN32_LEAN_AND_MEAN
#endif
#include <windows.h>
double second (void)
    LARGE_INTEGER t;
    static double oofreq;
    static int checkedForHighResTimer;
    static BOOL hasHighResTimer;
    if (!checkedForHighResTimer) {
        hasHighResTimer = QueryPerformanceFrequency (&t);
        oofreq = 1.0 / (double)t.QuadPart;
        checkedForHighResTimer = 1;
    if (hasHighResTimer) {
        QueryPerformanceCounter (&t);
        return (double)t.QuadPart * oofreq;
    } else {
        return (double)GetTickCount() * 1.0e-3;
#elif defined(__linux__) || defined(__APPLE__)
#include <stddef.h>
#include <sys/time.h>
    struct timeval tv;
    gettimeofday(&tv, NULL);
    return (double)tv.tv_sec + (double)tv.tv_usec * 1.0e-6;
#else
#error unsupported platform
#endif
__global__ void zcopy (const double2 * __restrict__ src,
                       double2 * __restrict__ dst, int len)
    int stride = gridDim.x * blockDim.x;
    int tid = blockDim.x * blockIdx.x + threadIdx.x;
    for (int i = tid; i < len; i += stride) {
        dst[i] = src[i];
struct zcopyOpts {
    int len;
    int dev;
static int processArgs (int argc, char *argv[], struct zcopyOpts *opts)
    int error = 0;
    memset (opts, 0, sizeof(*opts));
    while (argc) {
        if (*argv[0] == '-') {
            switch (*(argv[0]+1)) {
            case 'n':
                opts->len = atol(argv[0]+2);
                break;
            case 'd':
                opts->dev = atol(argv[0]+2);
                break;
            default:
                fprintf (stderr, "Unknown switch '%c%s'\n", '-', argv[0]+1);
                error++;
                break;
        argc--;
        argv++;
    return error;
int main (int argc, char *argv[])
    double start, stop, init_start, init_stop, elapsed, mintime;
    double2 *d_a, *d_b;
    int errors;
    struct zcopyOpts opts;
    errors = processArgs (argc, argv, &opts);
    if (errors) {
        return EXIT_FAILURE;
    opts.len = (opts.len) ? opts.len : ZCOPY_DEFLEN;
    opts.dev = (opts.dev) ? opts.dev : ZCOPY_DEFDEV;
    /* Trigger CUDA context creation */
    init_start = second();
    CUDA_SAFE_CALL (cudaFree (0));
    init_stop = second();
    printf ("CUDA initialization: %.3f seconds\n", init_stop - init_start);
    /* Select GPU to run on */
    struct cudaDeviceProp props;
    CUDA_SAFE_CALL (cudaSetDevice (opts.dev));
    CUDA_SAFE_CALL (cudaGetDeviceProperties (&props, opts.dev));
    printf ("zcopy: running on device %d (%s)\n", opts.dev, props.name);
    /* Allocate memory on device */
    CUDA_SAFE_CALL (cudaMalloc((void**)&d_a, sizeof(d_a[0]) * opts.len));
    CUDA_SAFE_CALL (cudaMalloc((void**)&d_b, sizeof(d_b[0]) * opts.len));
    /* Initialize device memory */
    CUDA_SAFE_CALL (cudaMemset(d_a, 0x00, sizeof(d_a[0]) * opts.len)); // zero
    CUDA_SAFE_CALL (cudaMemset(d_b, 0xff, sizeof(d_b[0]) * opts.len)); // NaN
    /* Compute execution configuration */
    dim3 dimBlock(ZCOPY_THREADS);
    int threadBlocks = (opts.len + (dimBlock.x - 1)) / dimBlock.x;
    dim3 dimGrid(threadBlocks);
    printf ("zcopy: using vectors of %d double2 elements (= %.3e bytes)\n",
            opts.len, (double)sizeof(d_a[0]) * opts.len);
    printf ("zcopy: using %d threads per block, %d blocks\n",
            dimBlock.x, dimGrid.x);
    mintime = fabs(log(0.0));
    for (int k = 0; k < ZCOPY_ITER; k++) {
        start = second();
        zcopy<<<dimGrid,dimBlock>>>(d_a, d_b, opts.len);
        CHECK_LAUNCH_ERROR();
        stop = second();
        elapsed = stop - start;
        if (elapsed < mintime) mintime = elapsed;
    printf ("zcopy: mintime = %.3f msec; eqv. memory bandwith = %.2f GB/sec\n",
            1.0e3 * mintime, (2 * sizeof(d_a[0]) * opts.len) / (1e9 * mintime));
    CUDA_SAFE_CALL (cudaFree(d_a));
    CUDA_SAFE_CALL (cudaFree(d_b));
    return EXIT_SUCCESS;
Thanks for explanation. The bandwidth peak is resolved.
I updated the topic a bit that when problem size is large enough, it cannot reproduce the bumped peak 1.8TB/s around 2M problem size for A100, but drop to 1.2TB/s.
Do you know the reason? If so, how can we use the vectorized mem copy if the problem is very large?
I do not have any hands-on experience with these supercomputer class GPUs that use HBM2e/HBM3 memory. There could well be performance artifacts based on the internal organization of these memories, such as internal banking, open/close page management, read / write interference.
You could try running this with the CUDA profiler to see whether you can spot some salient difference in the memory statistics.
Got it. Thank you all the same
