I am running vLLM across 2x DGX nodes connected via NVIDIA ConnectX-7 adapters using RoCE v2. During workloads, the multinode connection suddenly drops, causing the LLM serving process to hang or crash completely.
Upon debugging the RDMA state using show_gids, I discovered that the kernel dynamically restructures the GID table while vLLM is running. The active RoCE v2 mapping originally at index 3 suddenly gets cleared out to all zeros (0000:0000...), while the fresh RoCE v2 IPv4 entry shifts down to index 4.
Because our environment hardcodes NCCL_IB_GID_INDEX=3, vLLM crashes with the following error:
[glm53-exl3] head GID index 3 is EMPTY on rocep1s0f0
[glm53-exl3] worker GID index 3 is EMPTY on rocep1s0f0
[glm53-exl3] ERROR: set NCCL_IB_GID_INDEX (same index both ranks) or HEAD_GID/WORKER_GID (per rank) in .env to populated indices
Currently, the only way I can recover from this is by completely rebooting the systems or manually updating the .env configuration to index 4.
Has anyone else encountered this transient interface flapping/GID index drift on ConnectX-7 cards during heavy training or inference workloads? Is it something wrong with the driver/kernal? Any solution for this? Thank you.
GID index changes when a CX7 IP is added or removed, so if the link is flapping, this could affect the indexing.
Some suggestions:
Stop hard-coding the GID index. Unset NCCL_IB_GID_INDEX and let NCCL choose (recent NCCL versions select the GID automatically). If needed, pin the selection criteria rather than the index:
If something must take an index, compute it at launch:
p=/sys/class/infiniband/mlx5_0/ports/1
for g in $p/gids/*; do i=${g##*/}; [[ $(cat $p/gid_attrs/types/$i 2>/dev/null) == "RoCE v2" ]] && grep -q ffff "$g" && echo $i && break; done
Use static IPs instead of link-local on the CX7 ports, as in the Spark “connect two Sparks” playbook. For example, netplan with 192.168.100.x/24 and ignore-carrier: true. This keeps the address, and its GID, through brief carrier drops.
