I have two functions to compute gradient of 3D image. One function use the global memory directly, other use shared memory.
When I benchmark the speed of two function, the global memory function is 1.2Mpixels /second while the shared memory only achieves 170k.
the result runs on the Tesla S1070 with input size 256^3
So my question is why the shared memory version uses much less memory bandwidth but much slower (about 7 time slower) than the global version ?
What is the best practice for the stencil buffer problem, like gradient or FDM ? When we should use shared memory, when you should not
Any ideas are greatly appreciated!
Here are the codes
[codebox]
template
global void cudaComputeGradient_kernel(float * d_gdx, float * d_gdy, float * d_gdz,
float * d_i,
int w, int h, int l,
float sx, float sy, float sz)
int i = threadIdx.x + blockIdx.x * blockDim.x;
int j = threadIdx.y + blockIdx.y * blockDim.y;
int wh = w * h;
int id = j * w + i;
if (i<w && j < h)
for (int k=0 ; k < l; ++k, id += wh){
if (i == 0)
d_gdx[id] = (d_i[id+1] - d_i[id]) / sx;
else if (i == w - 1)
d_gdx[id] = (d_i[id] - d_i[id-1]) / sx;
else
d_gdx[id] = (d_i[id+1] - d_i[id-1]) / (2.f * sx);
if (j == 0)
d_gdy[id] = (d_i[id+w] - d_i[id]) / sy;
else if (j == h - 1)
d_gdy[id] = (d_i[id] - d_i[id-w]) / sy;
else
d_gdy[id] = (d_i[id+w] - d_i[id-w]) / (2.f * sy);
if (k == 0)
d_gdz[id] = (d_i[id+wh] - d_i[id]) / sz;
else if (k == l - 1)
d_gdz[id] = (d_i[id] - d_i[id-wh]) / sz;
else
d_gdz[id] = (d_i[id+wh] - d_i[id-wh]) / (2.f * sz);
void cudaComputeGradient(float * d_gdx, float * d_gdy, float * d_gdz, // out put gradient
float * d_i, // input image
uint w, uint h, uint l, // size of image
float sx, float sy, float sz) // spacing
dim3 threads(16,16);
dim3 grids(iDivUp16(w), iDivUp16(h));
cudaComputeGradient_kernel<<<grids, threads>>>(d_gdx, d_gdy, d_gdz, d_i,
w, h, l,
sx, sy, sz);
[/codebox]
[codebox]
global void cudaComputeGradient_shared_kernel(float * d_gdx, float * d_gdy, float * d_gdz,
float * d_i,
const int radius = 1;
float s_data[16 + radius * 2][16 + radius * 2];
if (i < w && j < h){
int planeSize = w* h;
int id = j * w + i;
float back = 0;
float current = 0;
float front = d_i[id];
for (int k=0; k< l; ++k){
back = current;
current = front;
front = d_i[id + planeSize];
__syncthreads();
int tx = threadIdx.x + radius;
int ty = threadIdx.y + radius;
if (threadIdx.x < radius){
s_data[ty][threadIdx.x] = d_i[id - radius];
s_data[ty][threadIdx.x + 16 + radius] = d_i[id + 16];
if (threadIdx.y < radius){
s_data[threadIdx.y][tx] = d_i[id - radius * w];
s_data[threadIdx.y + 16 + radius][tx] = d_i[id + 16 * w];
s_data[ty][tx] = current;
__syncthreads();
if (i == 0)
d_gdx[id] = (s_data[ty][tx+1] -s_data[ty][tx]) / sx;
d_gdx[id] = (s_data[ty][tx] -s_data[ty][tx-1]) / sx;
else
d_gdx[id] = (s_data[ty][tx+1] -s_data[ty][tx-1])/ (2 * sx);
if (j == 0)
d_gdy[id] = (s_data[ty+1][tx] -s_data[ty][tx]) /sy;
d_gdy[id] = (s_data[ty][tx] -s_data[ty-1][tx]) /sy;
else
d_gdy[id] = (s_data[ty+1][tx] -s_data[ty-1][tx])/(2 * sy);
if (k==0)
d_gdz[id] = (front - current)/sz;
d_gdz[id] = (current - back) /sz;
else
d_gdz[id] = (front - back) /(2 * sz);
id += planeSize;
void cudaComputeGradient_shared(float * d_gdx, float * d_gdy, float * d_gdz, // out put gradient
cudaComputeGradient_shared_kernel<<<grids, threads>>>(d_gdx, d_gdy, d_gdz, d_i,
w, h, l,
sx, sy, sz);
[/codebox]
