I am running a python code that contains a module of tensorflow light. The error is AttributeError: module ‘tensorflow’ has no attribute ‘lite’. I have tried most of the online solution, yet none of them worked.
PS: system information.
Package: nvidia-jetpack
Version: 4.5-b129
Architecture; arm64
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command. https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
