The cpu frequency of version 35.2.1 is not stable and vary from 729Mhz to 2.2Ghz with no load in normal temperature. Do you know the reason?
By default DFS(dynamic frequency scaling) is enabled for efficient power consumption. You can execute sudo jetson_clocks to always run in maximum frequency. Please also refer to developer guide:
Jetson Orin Nano Series, Jetson Orin NX Series and Jetson AGX Orin Series — Jetson Linux Developer Guide documentation
If I execute sudo jetson_clocks, the cpus are running in maximum frequency.But when the temperature is high, the cpu frequency is always maximum value. Is there any method to make that the cpu frequency is down when the temperature is high and sudo jetson_clocks is executed?
There’s mechanism to prevent overheating. Please check
