Why the downstream elements delay effect on the upstream probe function for measure fps
• Hardware Platform (Jetson / GPU): dPU A40.
• DeepStream Version: 6.4-triton-multiarch.
• TensorRT Version: 8.6.1.6.
• NVIDIA GPU Driver Version (valid for GPU only): 535.146.02.
• Issue Type( questions, new requirements, bugs): questions.
if i have pipeline “nvurisrcbin + probe function + nvinfer + sgie1 + sgie2 + fakesink”, the delay in all “nvinfer + sgie1 + sgie2” can effect on the probe function? how this happen? there any way can make probe function affected only by the upstream elements?
On the contrary, the delay in the probe function will impact the downstream flow.
DeepStream is based on GStreamer, please refer to GStreamer https://gstreamer.freedesktop.org/ document to understand how the GStreamer pipeline works.
If the downstream elements work fast enough, then the probe function is only affected by the upstream elements.
