Hi
I am using the Coral devboard (INT8) and the Jetson TX2(FP16) to test inference with the Inception_v1 model and an image of a Trimaran.
In Coral devboard, the preprocessing (this came with the devboard) is:
image = Image.open(args.input).convert(‘RGB’).resize(size, Image.ANTIALIAS)
When I apply it in the Jetson I change the dtype to FP32. Like this:
image = np.asarray(Image.open(image_path).convert('RGB').resize(size, Image.ANTIALIAS), dtype=np.float32)
The prediction that I get when using this preprocessing in the Jetson, is:
maximum value 0.9786956 : Oystercatcher
Meanwhile in Jetson is (check this GIT) https://github.com/NVIDIA-AI-IOT/tf_to_trt_image_classification/blob/master/scripts/model_meta.py:
def preprocess_inception(image):
return 2.0 * (np.array(image, dtype=np.float32) / 255.0 - 0.5)
image = np.asarray(Image.open(image_path).resize(size))
The prediction that I get is:
maximum value 0.6656681 : trimaran
What is happening? It is the same model: Inception_v1.
I am not sure why each devboard has their own preprocessing for the same model.
My goal is to benchmark both devboards. So ideally I should be using the same preprocessing. But now I am not sure.
