I have a kernel which contains a statically allocated array of 50 bytes. I compiled it using nvcc.
nvcc -I../ -c -arch=sm_30 --ptxas-options=-v kernel.cu
It doesn’t show usage of local memory i.e. lmem
ptxas info : 1024 bytes gmem
ptxas info : Compiling entry function '_Z28function_S_' for 'sm_30'
ptxas info : Function properties for _Z28function_S_
56 bytes stack frame, 0 bytes spill stores, 0 bytes spill loads
ptxas info : Used 22 registers, 368 bytes cmem[0], 4 bytes cmem[2]
I opened its ptx generated file and found the array declared in local memory
.local .align 1 .b8 __local_depot1[<u><b>50</b></u>];
.reg .b64 %SP;
.reg .b64 %SPL;
.reg .pred %p<14>;
.reg .b16 %rs<25>;
.reg .b32 %r<294>;
My question is; why the --ptxas-options=-v doesn’t show the lmem usage in its output.
$ nvcc --version
Copyright (c) 2005-2015 NVIDIA Corporation
Built on Tue_Aug_11_14:27:32_CDT_2015
Cuda compilation tools, release 7.5, V7.5.17
