Why the SHUTDOWN_REQ* pin is set as input?
Hi NVIDIA team,
I’m currently working with the Orin NX pinmux. I notice that the SHUTDOWN_REQ* pin direction is set as input. However, in the customer usage description it says that it needs to be pulled low by the module.
If it’s needed for the module to control this pin and set a value, why is it set as input and not output?
It is output, the pinmux will be corrected. In fact, this pin is not configurable.
