We just want to profile another tensorrt instance, and clone the Profiler C++ class in sampleGoogleNet.cpp file. It’s report time is strange, so I digged to the document and header file. It seems Profiler class should report time in second instead of millisecond, or just don’t divide time by TIMING_ITERATIONS(1000).
struct Profiler : public IProfiler
typedef std::pair<std::string, float> Record;
std::vector<Record> mProfile;
virtual void reportLayerTime(const char* layerName, float ms)
auto record = std::find_if(mProfile.begin(), mProfile.end(), [&](const Record& r){ return r.first == layerName; });
if (record == mProfile.end())
mProfile.push_back(std::make_pair(layerName, ms));
else
record->second += ms;
void printLayerTimes()
float totalTime = 0;
for (size_t i = 0; i < mProfile.size(); i++)
//the mProfile[i].second(according to first) is already in millisecond, why divide it by TIMING_ITERATIONS?
printf("%-40.40s %4.3f<b>ms</b>\n", mProfile[i].first.c_str(), mProfile[i].second / TIMING_ITERATIONS);
totalTime += mProfile[i].second;
printf("Time over all layers: %4.3f\n", totalTime / TIMING_ITERATIONS);
} gProfiler;
This is the reportLayerTime function declaration in NvInfer.h
virtual void nvinfer1::IProfiler::reportLayerTime ( const char * layerName,
float ms
pure virtual
layer time reporting callback
Parameters
layerName the name of the layer, set when constructing the network definition
ms the time in milliseconds to execute the layer
What’s wrong?
