I found when I use cudaHostRegister on my desktop which use rtx3060 the application is working, but when I use cudaHostRegister on jetson tx2, I got an error:
CUDA error at ../cuda_test.cu:59 code=801(cudaErrorNotSupported) "cudaHostRegister(data, size, cudaHostRegisterDefault)"
CUDA error at ../cuda_test.cu:59 code=801(cudaErrorNotSupported) "cudaHostRegister(data, size, cudaHostRegisterPortable)"
CUDA error at ../cuda_test.cu:59 code=801(cudaErrorNotSupported) "cudaHostRegister(data, size, cudaHostRegisterMapped)"
CUDA error at ../cuda_test.cu:59 code=801(cudaErrorNotSupported) "cudaHostRegister(data, size, cudaHostRegisterIoMemory)"
why tx2 not support cudaHostRegister? is there any other way to reduce memery copy?
thank you.
