Why using "delete" instead of "delete []" to delete mask array pointer?
In function InferPostprocessor::releaseFrameOutput(NvDsInferFrameOutput& frameOutput):
case NvDsInferNetworkType_InstanceSegmentation:
  delete frameOutput.detectionOutput.objects[j].mask;
And mask is initialize as :
float *mask = (float *)g_malloc(obj.mask_size);
So mask is a pointer to an array, which need to be released by using delete []
Mask in struct NvDsInferObject is assumably an array of float. It’s probably allocated by either new [mask_size] or malloc(mask_size). So it should be deallocated by delete [] or free. Not sure why in deepstream implementation it uses delete.
Seems mismatch between allocation and free. We will check it. Thanks for reporting it.
@kesong any updates on this?
We will fix it in the following release of Deepstream. Thanks for reporting the issue.
