Why using the new Orin, does replacing the Image and dtb files result in an ineffective startup?
First, I compiled the kernel image and dtb.
sudo cp Image /boot/Image
sudo cp tegra234-p3701-0000-p3737-0000.dtb /boot/dtb/kernel_tegra234-p3701-0000-p3737-0000.dtb
sudo reboot
But It seems that the changes take effect after using the command sudo ./flash.sh jetson-agx-orin-devkit internal to flash the complete firmware. Thank you for the additional information.
The content of the extlinux.conf file is as follows.
nvidia@nvidia-desktop:~$ cat /boot/extlinux/extlinux.conf
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
      MENU LABEL primary kernel
      LINUX /boot/Image
      FDT /boot/dtb/kernel_tegra234-p3701-0000-p3737-0000.dtb
      INITRD /boot/initrd
      APPEND ${cbootargs} root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
# When testing a custom kernel, it is recommended that you create a backup of
# the original kernel and add a new entry to this file so that the device can
# fallback to the original kernel. To do this:
# 1, Make a backup of the original kernel
#      sudo cp /boot/Image /boot/Image.backup
# 2, Copy your custom kernel into /boot/Image
# 3, Uncomment below menu setting lines for the original kernel
# 4, Reboot
LABEL backup
    MENU LABEL backup kernel
    LINUX /boot/Image.backup
    FDT /boot/dtb/kernel_tegra234-p3701-0000-p3737-0000.dtb.backup
    INITRD /boot/initrd
Hi Dingdongkk,
Do you mean that there’s no change after you replacing the kernel image/dtb?
Or you hit any boot up issue?
What do you modify in kernel image and dtb?
Yes, own board is Jetson AGX Orin development kit.
I mean that there’s no change after I replacing the kernel image/dtb.
By downloading the sorce code of l4T 35.3.1 and compling it to produce Image.
Kernel Image and DTB may be loaded from partition instead of loading from rootfs.
Please flash the whole board to apply the change.
Okay,That works. Thank you.
