It worked OK on 35.4.1, but on 36.3.0
v4l2-ctl -d /dev/video1 --set-ctrl sensor_mode=2 --set-fmt-video=width=2592,height=1944 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to test.raw --verbose
returns this. All these lines are 32 pixels wide, which suggests that somebody forgot to flush.
But nvargus_nvraw works OK
hello jhnlmn,
it’s JP-6.0/r36.3 known issue, (line artifacts), and we’ve resolved this failure recently.
please refer to Topic 299834 for the bug fixes.
thanks
Sorry, I missed Topic 299834 in my searches because it did not mention v4l2-ctl.
It mentions “VI-Mode”, which is not defined in the docs.
So, if my own app I am calling VIDIOC_STREAMOFF/VIDIOC_QBUF/VIDIOC_DQBUF, is it considered “VI-Mode”? Is it affected?
I do not see the image problems in my app, but may be I did not look hard enough?
or, may be, the way I use V4L is different from v4l2-ctl and I am not affected?
In Topic 299834 you have 2 patches: for DTS and kernel. Are both of them necessary? I do not mind changing DTS (since it is needed for camera anyway), but until now I avoided changing kernel.
May be I should wait for a fix from Nvidia? Are there any time estimates?
Thank you
hello jhnlmn,
please see-also Camera Architecture Stack, it’s the memory handling issue with VI driver.
if you using v4l2-ctl, it could be workaround by dropping some frames, i.e. --stream-skip
options.
for instance, issue gone if you try skip frames (as many as possible) to dump a raw file via v4l2.
$ v4l2-ctl -d /dev/video0 --set-fmt-video=width=1920,height=1080,pixelformat=RG10 --stream-skip=999 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=/tmp/frame1920x1080.raw
I don’t have schedule for next JP-6 public release yet.
please include all the fixes to address the line artifacts issue.
