I am trying to capture a single frame on IMX264 using v4l2-ctrl command given bellow.
v4l2-ctl -V --set-fmt-video=width=2464,height=2058,pixelformat=RG12 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=imx264.raw -d /dev/video1
In dmesg it shows 5 frames are captured.
[ 467.367208] imx264 31-0010: imx264_power_on: power on
[ 467.373671] nvcsi 150c0000.nvcsi: csi port:0
[ 467.378555] nvcsi 150c0000.nvcsi: csi port:2
[ 467.383034] nvcsi 150c0000.nvcsi: csi port:4
[ 467.423510] tegra-vi4 15700000.vi: Create Surface with imgW=2464, imgH=2058, memFmt=32
[ 467.432246] nvcsi 150c0000.nvcsi: csi4_start_streaming ports index=2, lanes=4
[ 467.439407] nvcsi 150c0000.nvcsi: csi4_stream_init
[ 467.444221] nvcsi 150c0000.nvcsi: csi4_stream_config
[ 467.449200] nvcsi 150c0000.nvcsi: csi4_stream_config (2) read VC0_DPCM_CTRL = 00000000
[ 467.457124] nvcsi 150c0000.nvcsi: csi4_phy_config
[ 467.461836] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000000
[ 467.467596] nvcsi 150c0000.nvcsi: cil_settingtime is pulled from device
[ 467.474211] nvcsi 150c0000.nvcsi: cil core clock: 204, csi clock: 102
[ 467.480657] nvcsi 150c0000.nvcsi: cil_settingtime was autocalculated
[ 467.487014] nvcsi 150c0000.nvcsi: csi settle time: 33, cil settle time: 25
[ 467.493908] imx264 31-0010: imx264_s_stream++ enable 1
[ 467.586715] video4linux video1: tegra_channel_capture_frame: vi4 got SOF syncpt buf[ffffffc07a97b000]
[ 467.595951] video4linux video1: tegra_channel_release_frame: vi4 got EOF syncpt buf[ffffffc07a97b000]
[ 467.605174] video4linux video1: release_buffer: capture init latency is 183 ms
[ 467.612404] video4linux video1: release_buffer: release buf[ffffffc07a97b000] <b>frame[1]</b> to user-space
[ 467.720022] video4linux video1: tegra_channel_capture_frame: vi4 got SOF syncpt buf[ffffffc07a978800]
[ 467.729253] video4linux video1: tegra_channel_release_frame: vi4 got EOF syncpt buf[ffffffc07a978800]
[ 467.738475] video4linux video1: release_buffer: release buf[ffffffc07a978800] <b>frame[2]</b> to user-space
[ 467.853348] video4linux video1: tegra_channel_capture_frame: vi4 got SOF syncpt buf[ffffffc07a97a400]
[ 467.862600] video4linux video1: tegra_channel_release_frame: vi4 got EOF syncpt buf[ffffffc07a97a400]
[ 467.872032] video4linux video1: release_buffer: release buf[ffffffc07a97a400] <b>frame[3]</b> to user-space
[ 467.986670] video4linux video1: tegra_channel_capture_frame: vi4 got SOF syncpt buf[ffffffc07a978000]
[ 467.995970] video4linux video1: tegra_channel_release_frame: vi4 got EOF syncpt buf[ffffffc07a978000]
[ 468.005215] video4linux video1: release_buffer: release buf[ffffffc07a978000] <b>frame[4]</b> to user-space
[ 468.041854] video4linux video1: release_buffer: release buf[ffffffc07a97b000] <b>frame[5]</b> to user-space
[ 468.051153] imx264 31-0010: imx264_s_stream++ enable 0
[ 468.077525] nvcsi 150c0000.nvcsi: csi4_stop_streaming ports index=0, lanes=4
[ 468.084598] nvcsi 150c0000.nvcsi: csi4_phy_config
[ 468.089327] nvcsi 150c0000.nvcsi: NVCSI_CIL_CONFIG = 00000004
[ 468.095089] nvcsi 150c0000.nvcsi: csi4_stream_check_status
[ 468.100592] nvcsi 150c0000.nvcsi: csi4_cil_check_status 340
[ 468.117252] imx264 31-0010: imx264_power_off: power off
Why It is capturing 5 frames instead of one frame?
Is there any way to capture only single frame?
