I modified the SDK vector addiction example to use zero copy memory,but for some reason the result isn’t what it should have been.
I’m attaching the code:
* Copyright 1993-2010 NVIDIA Corporation. All rights reserved.
* Please refer to the NVIDIA end user license agreement (EULA) associated
* with this source code for terms and conditions that govern your use of
* this software. Any use, reproduction, disclosure, or distribution of
* this software and related documentation outside the terms of the EULA
* is strictly prohibited.
/* Vector addition: C = A + B.
* This sample is a very basic sample that implements element by element
* vector addition. It is the same as the sample illustrating Chapter 3
* of the programming guide with some additions like error checking.
// Includes
#include <stdio.h>
// Variables
float* h_A;
float* h_B;
float* h_C;
float* d_A;
float* d_B;
float* d_C;
bool noprompt = false;
// Functions
void Cleanup(void);
void RandomInit(float*, int);
// Device code
__global__ void VecAdd(const float* A, const float* B, float* C, int N)
int i = blockDim.x * blockIdx.x + threadIdx.x;
if (i < N)
C[i] = A[i] + B[i];
// Host code
int main(int argc, char** argv)
printf("Vector addition\n");
int N = 50000;
int size = N * sizeof(float);
cudaSetDeviceFlags(cudaDeviceMapHost);
// Allocate vectors in device memory
cudaHostAlloc( (void**)&h_A,size,cudaHostAllocMapped ) ;
cudaHostAlloc( (void**)&h_B,size,cudaHostAllocMapped ) ;
cudaHostAlloc( (void**)&h_C,size,cudaHostAllocMapped ) ;
// Initialize input vectors
RandomInit(h_A, N);
RandomInit(h_B, N);
cudaHostGetDevicePointer(&d_A,h_A, 0);
cudaHostGetDevicePointer(&d_B, h_B, 0);
cudaHostGetDevicePointer(&d_C, h_C, 0);
// Invoke kernel
int threadsPerBlock = 256;
int blocksPerGrid = (N + threadsPerBlock - 1) / threadsPerBlock;
VecAdd<<<blocksPerGrid, threadsPerBlock>>>(d_A, d_B, d_C, N);
cudaDeviceSynchronize();
// Verify result
int i;
for (i = 0; i < N; ++i) {
float sum = h_A[i] + h_B[i];
if (fabs(h_C[i] - sum) > 1e-5)
break;
printf("%s\n", (i == N) ? "PASSED" : "FAILED");
Cleanup();
void Cleanup(void)
// Free host memory
if (h_A)
cudaFreeHost(h_A);
if (h_B)
cudaFreeHost(h_B);
if (h_C)
cudaFreeHost(h_C);
cudaDeviceReset();
exit(0);
// Allocates an array with random float entries.
void RandomInit(float* data, int n)
for (int i = 0; i < n; ++i)
data[i] = rand() / (float)RAND_MAX;
Edit:i fixed the mistakes now the above program works as it should.
