What can be the reason of messages below ?
NV_Warning: Signal shared_load can not be profiled in this run.
NV_Warning: Signal shared_store can not be profiled in this run.
NV_Warning: Signal branch can not be profiled in this run.
NV_Warning: Signal warps_launched can not be profiled in this run.
NV_Warning: Signal active_cycles can not be profiled in this run.
NV_Warning: Signal sm_cta_launched can not be profiled in this run.
NV_Warning: Signal l1_global_load_hit can not be profiled in this run.
NV_Warning: Profiler counters are disabled for this context.
As a result, that’s the only info that profiler provides (under the standard header of profiler output table):
1.44997e+07 Kernel 7259.71 4.932 60 640 23040 0 50 0.417 0
