how come the deepseek models are no longer able to be used for api keys? are they returning to free use? or is it a model change for them that is happening?
I would like to know the same thing.
I have been using them for months. And since this morning they are gone…I hope someone from the dev team can explain this to us.
they were gone with no warning… it caught me off guard. i hope they bring them back with the newer optimized models, though i wouldn’t bet on it…
In the APIs catalogue now they are shown as “deprecated”…so now all Deepseek models are gone from Nim.
I hope they can give us some explanation.
Probably to free up servers for the Kimi K3, as well as the updated Deepseek V4 Flash. It would be nice if they gave a seven-day notice before removing models, but I understand why they’re doing it this way. They can’t keep 6-10 big models while adding 2-3 other big models. Deepseek v4 Flash probably will be back in 1-3 days, and they might also update Kimi to K3 this week.
I also understand why the Nvidia NIM team does not explain anything or does not respond to anyone, due to the disgusting attitude towards them from abusers and free users.
Update: The new and improved Deepseek V4 Flash is now available via API, although it’s not listed on the website or API docs. I recommend checking the list of models via the API rather than the website.
Yes, I noticed; However, the DeepSeek v4 Pro model was removed alongside DeepSeek v4 Flash, and it has not been reinstated. As far as I know, DeepSeek v4 Flash 0731 was only an upgrade to the v4 Flash model, and not the Pro model. But they seem to have removed both and replaced them with v4 flash 0731. It seems inappropriate for them to deprecate the V4 Pro model with another one that was not intended to be an upgrade to it.
If they have decided to remove V4 Pro permanently due to compute cost (or a similar reason), then I suppose.
Edit: I did look into some benchmarks regarding V4 Flash 0731, and it does seem to beat even V4 Pro on several benchmarks, so it can likely be used over it. Although I have only skimmed through some benchmark reports and what other people have to say about the model, I am going to try it myself later.
august 10th has release of the fully trained v4 pro? or something of the sort on the 10th. they have an end goal there.
The Deepseek V4 Pro was probably removed to add Kimi K3. The Kimi K3 is too big. (Deepseek V4 Flash 0731, NOT Deepseek V3 Pro 0731)
I am currently trying the new V4 Flash and it is not bad at all. I also was quite comfortable with V4 Pro. But it is what it is i guess…
