Hi NVIDIA Community,
We are facing a Wi-Fi issue after upgrading from JetPack 5.1.1 to 6.2.1 (Ubuntu 22.04) on our custom carrier boards.
Previously, a TP-Link USB Wi-Fi adapter worked reliably with JP 5.1.1. With JP 6.2.1, it no longer works. TP-Link confirmed that the adapter is old and does not have newer Ubuntu 22.04 drivers.
We then switched to an Intel Wireless-AC 8265 M.2 module.
It initially worked on an AVerMedia D131 board, but after a few successful tests, Wi-Fi stopped appearing. Bluetooth continues to work normally.
We also tested the AC8265 on a new carrier board from a different vendor, but Wi-Fi is still not detected while Bluetooth works.
Current setup:
- JetPack 6.2.1 / Ubuntu 22.04
- Intel AC8265
- Bluetooth: detected and working
- Wi-Fi: completely missing
Could this be related to PCIe configuration, device tree, power/reset, iwlwifi firmware, or kernel/driver compatibility?
What logs/commands would you recommend checking to identify the root cause?
Also, as a quick workaround, can anyone recommend a USB Wi-Fi adapter known to work reliably with JetPack 6.2.1 / Ubuntu 22.04, preferably with an in-tree Linux driver?
