Wi-Fi on the Spark much slower than another machine on the same Wi-Fi 7 router (MT7925, MLO)
My Spark sits away from the router, so for now it is on Wi-Fi. It gets far less throughput than another machine on the same network, and I’d like to know whether this is a known issue.
Setup
  • DGX OS 7.2.3 (Ubuntu 24.04.5), kernel 7.0.0-1019-nvidia
  • Wi-Fi: MediaTek MT7925 (mt7925e, firmware 20260605184805)
  • Router: Telefónica, Wi-Fi 7
  • The Spark connects with MLO on two links: channel 6 at 2.4 GHz (20 MHz) and channel 52 at 5 GHz (160 MHz). Signal −64 dBm. iw reports 864–1152 Mbit/s.
What I see
I streamed 1 GB over SSH from a wired machine to each node, and also read 2 GB from network storage on each:
Link Raw stream Storage read
Spark Wi-Fi 7, MLO (2.4 + 5 GHz) 3 MB/s 8 MB/s
Other machine (same room, same router) Wi-Fi 6, 5 GHz, 80 MHz, −61 dBm 49 MB/s 57 MB/s
Already checked
  • Wi-Fi power saving is off (iw reports Power save: off; NetworkManager has wifi.powersave = 3).
  • I saw the thread on TCP corruption with 7.0.0-1019-nvidia. Here TcpInCsumErrors stays at 0.
Questions
  1. Is low throughput with the MT7925 under MLO a known issue on the Spark?
  2. Is there a recommended way to disable MLO, or to keep the Spark on 5 GHz only, without changing the router?
  3. Is there a newer driver or firmware for the MT7925 than what ships with this DGX OS build?
I’ve ordered a switch and will wire it soon, but I’d like to understand this for anyone else running a Spark on Wi-Fi.
@alex.martinez.c you’ll have to disable MLO on your Telefónica router. Do a test with and w/out MLO and let us know the results.
Movistar’s router doesn’t let me turn off MLO without splitting the bands into two networks. Wi-Fi 7 certification requires MLO support (and DGX Spark claims WIFI 7 support), but a client can still connect on a single link. Is there a way to make the Spark’s MT7925 do that from the Spark side, for example with NetworkManager or a driver option?.
The Linux module doesn’t offer a method to toggle MLO on the Spark:
dgxspark@spark1:~$ modinfo mt7925e
filename:       /lib/modules/7.0.0-1019-nvidia/kernel/drivers/net/wireless/mediatek/mt76/mt7925/mt7925e.ko.zst
license:        Dual BSD/GPL
description:    MediaTek MT7925E (PCIe) wireless driver
author:         Lorenzo Bianconi <lorenzo@kernel.org>
author:         Deren Wu <deren.wu@mediatek.com>
firmware:       mediatek/mt7925/WIFI_MT7925_PATCH_MCU_1_1_hdr.bin
firmware:       mediatek/mt7925/WIFI_RAM_CODE_MT7925_1_1.bin
srcversion:     CA5A7C7E8E000B161560F48
alias:          pci:v000014C3d00000717sv*sd*bc*sc*i*
alias:          pci:v000014C3d00007925sv*sd*bc*sc*i*
depends:        mt792x-lib,mt76-connac-lib,mt76,mt7925-common
intree:         Y
vermagic:       7.0.0-1019-nvidia SMP preempt mod_unload modversions aarch64
sig_id:         PKCS#7
signer:         Build time autogenerated kernel key
sig_key:        63:D3:83:F6:06:BA:A7:A3:55:CF:3A:CC:6E:AD:42:02:50:D7:CD:68
sig_hashalgo:   sha512
signature:      A0:EC:31:B6:AE:EE:BE:67:31:4D:5D:D0:FA:8C:2A:F7:3D:F2:07:04:
                <-- cut -->
parm:           disable_aspm:disable PCI ASPM support (bool)
The only option is disable.aspm
