WiFi and Bluetooth is not working on my Jetson Xavier NX after I installed the M2-JODY-W377-00C module (M2-JODY-W3 card) on the M.2 E-key slot. I have 3 u.fl antennas hooked up to the module as well.
It is not seeing the card when I type in lspci or lsusb in the terminal. I am also not seeing anything on the the WiFi settings on the desktop.
I am guessing that all the necessary drivers are not installed. Please advice on where I can find the drivers to install this card and get WiFi and Bluetooth working correctly.
I tried the nRF52840 M.2 Module module as well. This is a Bluetooth module from Nordic. Doesn’t seem to work. I tried the same nrf52840 chip set as a USB dongle. Also didn’t work.
I also tried Alfa AWUS036AC WiFi USB dongle. It detects it when I type lsusb. Doesn’t work.
I just placed the order for 2 WiFi modules in the M.2 E Key form factor from Intel (Intel 8265 and Intel 9260. Should arrive today. I’ll try those as well and keep you posted.
From all the tests I have done so far, the M.2 modules doesn’t seem to be “detected” nor “working”
I am using the reComputer j202 carrier board. It says on their website that it 1:1 matches the size and functional design as the carrier board of Nvidia’s official Jetson Xavier NX Developer Kit.
It is most likely some gpios are needed to be enabled so that those cards will set status to enabled.
Please check with the card vendor if this is needed.
