I am trying to stream a video (3840x1080) on a Jetson Nano over the Jetson’s hotspot using gstreamer,
If use the Intel wifi card (link) everything works perfectly, the stream is very good, and almost no delay at all.
However when I use this USB wifi dongle (link), the stream is very corrupted, I can’t even tell what’s in the frame, it’s all corrupted pixels.
I am using the exact same gstreamer command below , nothing has changed.
gst-launch-1.0 -e v4l2src device=/dev/video1 ! 'video/x-raw, width=(int)3840, height=(int)1080, framerate=(fraction)30/1' ! nvvidconv ! nvv4l2h264enc bitrate=8000000 insert-sps-pps=true ! rtph264pay mtu=1400 ! udpsink host=10.42.0.153 port=5000 sync=false async=false
PC Client reciever
gst-launch-1.0 udpsrc port=5000 ! application/x-rtp,encoding-name=H264,payload=96 ! rtph264depay ! h264parse ! queue ! avdec_h264 ! xvimagesink sync=false async=false -e
Any ideas why this is happening and if it is fixable ?
