I recently purchased a Jetson Orin Nano board and worked on the tutorials using JetPack 6.0. The wifi connection worked fine originally. Starting today, I had a problem with my wifi connection. It kept asking me for my wifi password and failed to make the connection. My other devices (laptop, phones, etc.) have no problem with the same wifi connection. I have also reset the router but to no avail. When I powered off the board and restarted it, it did have a Wi-Fi connection for a while (I can browse several web pages.) Then it asked for the wifi password again and again. Any solution for this? Thanks.
Thanks for visiting the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
Not sure if it’s related with Ubuntu network manager, or WiFi driver.
Which WiFi module you used?
Do I have any choice? Just the one on the board. I didn’t make any changes or add any other devices for WiFi. If it is related to Ubuntu network manager and WiFi driver, is there anyway that I can somehow reset them?
We would suggest re-flash the system image and check if it goes back to normal. To confirm it is not a hardware defect.
And you may try to enable the configs:
Jetson/L4T/r36.3.x patches - eLinux.org
Enable AX210 WIFI module
The configs may be required for certain WIFI modules.
