WiFi drops when QSFP connected (MSI)
Has anyone seen an issue where the WiFi won’t connect when a QSFP56 cable is connected to the left (closer to the USB ports) port? This is on an MSI EdgExpert. Works fine on a DGX Spark in the left port. Works fine on both MSI and Spark when connected to the right port. Should be identical software configs across both, and this was before running anything from the Connect Two Sparks playbook.
I’m not hugely bothered by this since I don’t see expanding beyond two GB10s, and 10G ethernet is probably a good backup if the WiFi bails, but it’s still a bit concerning.
Connect Two Sparks playbook is running fine when using the right ports on both, other than the 107gbps limit when testing with iperf3.
If this is an issue specifically with the MSI EdgExpert, you should contact them for better support.
Switched to the officially recommended 0.4m Amphenol cable from the NVIDIA store and all seems well. I guess they really are that finicky :)
