Wifi M.2 Intel 3168NGW loading but can not use it
So I got a dual use card with WiFi and bluetooth and it works for bluetooth works fine but the WiFi will not come up.
I checked the intel site and saw this en:users:drivers:iwlwifi [Linux Wireless] and from what I can tell from the install of Ubuntu 18.02 the kernel and firmware are all in place.
I see the card with lspci. I also see that the kernel module are fully loaded.
I not sure what else I need to do to get the WiFi to work.
Command output:
lspci
lspci
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1)
00:02.0 PCI bridge: NVIDIA Corporation Device 0faf (rev a1)
01:00.0 Network controller: Intel Corporation Dual Band Wireless-AC 3168NGW [Stone Peak] (rev ff)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
lsmod
lsmod
Module                  Size  Used by
fuse                  103841  5
bnep                   16562  2
btusb                  40149  0
btrtl                   7318  1 btusb
btbcm                   8808  1 btusb
btintel                10771  1 btusb
iwlmvm                368205  0
mac80211              719792  1 iwlmvm
iwlwifi               167043  1 iwlmvm
cfg80211              589351  3 iwlmvm,iwlwifi,mac80211
nvs                    54527  0
nvgpu                1555053  50
bluedroid_pm           13912  0
ip_tables              19441  0
x_tables               28951  1 ip_tables
Andy
“lspci -vvv” should give out the driver for each card. Could you check if the driver behind “Intel Corporation Dual Band Wireless-AC 3168NGW” is iwlwifi?
If so, could you share the result of “sudo rfkill -list” ?
Here is the output of lspci -vvv and yah see an error
01:00.0 Network controller: Intel Corporation Dual Band Wireless-AC 3168NGW [Stone Peak] (rev ff) (prog-if ff)
	!!! Unknown header type 7f
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
So here is the output of rfkill
sudo rfkill list
0: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
So yah the card is not seen.
Also here is output form dmesg
[   12.301905] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.301912] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.301919] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.301926] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.301937] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.301947] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.301957] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.301973] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.301980] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.301988] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.301999] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302009] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302019] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302030] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302040] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302051] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302061] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302072] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302082] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302092] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302103] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302113] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302124] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302134] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302145] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302155] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302166] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302176] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302186] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302197] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302207] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302217] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302228] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302238] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302248] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302259] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302269] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302280] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302290] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302301] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302312] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302321] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302332] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302342] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302353] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302363] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302374] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302384] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302394] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302405] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302415] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302426] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302436] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302446] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302456] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302467] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302477] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302488] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302498] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302508] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302519] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302529] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302540] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302550] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302561] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302571] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302581] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302592] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302602] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302613] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302623] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302640] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302647] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302654] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302665] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302675] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302685] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302696] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302706] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302716] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302727] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302737] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302748] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302758] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302769] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302779] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302789] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302800] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302810] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302820] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302831] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302841] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302852] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302862] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302873] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302883] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302893] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302904] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302914] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302925] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302935] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302945] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302956] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302966] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302976] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302987] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.302997] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303008] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303018] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303029] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303039] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303049] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303060] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303070] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303081] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303091] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303101] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303112] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303122] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303132] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303143] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303154] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303164] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303174] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303185] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303195] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303205] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303232] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303239] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303246] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303253] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303260] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303268] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303278] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303293] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303300] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303309] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303320] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303330] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303341] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303351] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303362] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303372] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303382] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303393] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303403] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303413] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303424] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303434] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303445] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303455] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303466] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303476] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303486] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303497] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303507] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303517] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303528] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303538] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303549] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303559] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303570] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303580] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303591] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303601] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303611] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303622] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303632] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303642] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303653] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303663] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303674] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303684] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303694] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303705] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303715] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303726] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303736] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303746] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303757] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303767] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303778] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303788] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303799] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303809] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303820] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303830] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303840] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303851] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303861] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303872] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303882] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303892] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303903] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303913] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303923] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303934] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303944] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303958] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303965] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303975] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303986] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.303996] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304006] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304017] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304027] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304038] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304048] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304058] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304069] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304080] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304090] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304100] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304111] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304121] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304131] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304142] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304152] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304163] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304173] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304184] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304194] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304204] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304215] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304225] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304235] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304246] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304256] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304267] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304277] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304287] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304298] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304308] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304319] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304329] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304340] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304350] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304360] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304371] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304381] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304391] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304402] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304412] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304423] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304433] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304443] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304454] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304464] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304475] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304485] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304495] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304506] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304516] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304527] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304537] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304547] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304558] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304568] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304579] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304589] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304599] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304610] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304625] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304633] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304641] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304651] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304662] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304672] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304682] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304693] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304703] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304714] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304724] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304735] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304745] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304755] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304766] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304776] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304786] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304797] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304807] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304818] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304829] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304839] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304849] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304859] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304870] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304881] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304890] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304901] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304911] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304922] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304933] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304943] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304953] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304964] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304974] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304984] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.304995] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305005] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305016] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305026] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305036] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305047] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305057] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305068] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305078] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305089] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305099] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305109] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305119] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305130] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305140] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305155] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305163] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305180] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305188] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305195] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305202] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305213] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305223] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305234] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305244] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305255] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305265] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305283] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305291] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305298] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305312] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305319] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305327] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305338] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305348] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305363] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305370] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305380] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305390] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305400] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305411] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305424] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305432] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305444] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305453] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305463] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305475] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305485] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305500] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305508] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305516] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305531] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305539] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305546] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305556] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305567] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305578] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305588] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305632] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305640] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305647] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305654] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305661] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305675] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305682] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305692] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305702] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305713] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305723] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305734] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305744] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305754] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305765] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305775] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305785] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305796] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305806] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305817] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305827] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305837] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305848] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305858] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305868] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305879] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305890] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305900] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305910] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305921] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305935] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305954] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305961] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305968] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305976] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305983] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.305993] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306004] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306014] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306025] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306035] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306045] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306056] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306066] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306077] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306087] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306097] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306108] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306118] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306129] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306139] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306149] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306160] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306170] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306182] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306191] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306203] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306212] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306223] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306233] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306243] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306254] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306264] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306274] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306285] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306296] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306306] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306316] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306326] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306337] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306347] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306358] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306368] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306379] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306389] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306400] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306410] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306436] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306443] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306450] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306457] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306465] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306472] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306483] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306493] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306504] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306514] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306524] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306535] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306545] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306556] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306566] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306577] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306587] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306597] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306607] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306618] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306628] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306639] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306649] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306659] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306670] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306680] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306691] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306701] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306712] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306722] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306732] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306743] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306753] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306764] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306775] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306784] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306795] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306805] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306816] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306826] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306837] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306847] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306860] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306867] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306878] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306894] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306902] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306909] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306920] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306940] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306949] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306956] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306963] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306971] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306989] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.306997] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307004] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307014] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307023] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307034] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307044] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307055] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307065] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307075] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307086] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307096] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307106] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307117] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307127] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307138] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307148] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307158] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307169] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307179] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307190] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307200] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307210] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307232] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307239] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307246] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307263] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307270] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307277] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307284] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307318] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307325] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307340] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307347] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307354] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307361] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307369] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307377] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307387] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307398] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307409] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307419] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307431] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307444] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307452] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307460] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307472] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307481] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307494] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307502] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307517] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307525] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307533] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307543] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307554] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307564] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307575] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307585] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307595] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307612] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307620] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307627] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307640] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307647] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307659] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307669] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307678] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307690] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307699] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307710] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307720] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307732] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307741] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307751] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307763] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307771] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307782] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307794] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307803] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307813] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307825] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307834] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307845] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307856] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307866] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307876] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307887] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307897] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307912] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307919] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307928] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307938] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307950] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307959] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307972] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307980] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.307993] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308001] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308011] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308022] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308035] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308043] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308052] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308066] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308073] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308085] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308096] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308104] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308115] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308126] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308136] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308147] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308157] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308167] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308179] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308188] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308198] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308210] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308219] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308231] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308240] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308250] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308262] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308271] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308282] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308293] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308302] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308312] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308325] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308333] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308344] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308354] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308364] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308376] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308385] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308396] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308406] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308418] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308427] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308437] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308452] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308460] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308468] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308482] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308490] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308499] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308510] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308520] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signature: 13000025
[   12.308532] tegra-pcie 1003000.pcie-controller: PCIE: Response decoding error, signatur
Is this on TX1 or TX2? Also can you please give the release you are using?
Nano running the current released code.
Exact same problem. Bluetooth seems working fine.
miku@JestonNano:~$ lsusb
Bus 002 Device 002: ID 0bda:0411 Realtek Semiconductor Corp.
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 8087:0aa7 Intel Corp.
Bus 001 Device 006: ID 2f0e:0102
Bus 001 Device 005: ID 046d:c539 Logitech, Inc.
Bus 001 Device 004: ID 2717:ff80
Bus 001 Device 002: ID 0bda:5411 Realtek Semiconductor Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
miku@JestonNano:~$ lspci
00:01.0 PCI bridge: NVIDIA Corporation Device 0fae (rev a1)
00:02.0 PCI bridge: NVIDIA Corporation Device 0faf (rev a1)
01:00.0 Network controller: Intel Corporation Dual Band Wireless-AC 3168NGW [Stone Peak] (rev ff)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
I second this with the Jetson Nano + Intel Corporation Dual Band Wireless-AC 3168NGW + latest build and updates.
I am using the barrel jack for power.
From what I can tell from all the research I have done. It looks to be the WiFi chip is over heating. Not sure why it even dose this right as it boots but yah.
I removed it but now i have the Fan installed I may try and see if it works again.
I just unplugged my wifi and I have had a fan on it the whole time.
I would suggest just switching to an Intel 8265NGW module instead, as that is officially validated (at least on the elinux page). I use it and it is a straight plug and play, has been fast and very reliable.
Also if you are not using an antenna, I would suggest that as well. It is bad for the RF circuit on the wifi module to run without it, and could possibly be the cause of overheating.
I am using antenna and have been.
I forgot to mention that Bluetooth shows up. I haven’t tried using it but I am able to toggle on and off.
Any update on this ? I am able to use the bluetooth but no wifi using 3168NGW
hi,
in /boot/extlinux/extlinux.conf, add underlined text:
LABEL primary
      MENU LABEL primary kernel
      LINUX /boot/Image
      INITRD /boot/initrd
      APPEND ${cbootargs} quiet <u>pcie_aspm=off</u>
reboot and enjoy
ps: found on a forum page about 3165NGW on TX1 with the same error, sending with my nano in Wifi with it:
sudo lspci -vvv
01:00.0 Network controller: Intel Corporation Dual Band Wireless-AC 3168NGW [Stone Peak] (rev 10)
	Subsystem: Intel Corporation Device 2110
	Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
	Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
	Latency: 0
	Interrupt: pin A routed to IRQ 406
	Region 0: Memory at 13000000 (64-bit, non-prefetchable)
	Capabilities: <access denied>
	Kernel driver in use: iwlwifi
	Kernel modules: iwlwifi
edit: sources:
https://devtalk.nvidia.com/default/topic/1055070/jetson-tx2/failed-to-install-intel-3165ngw-in-jetson-tx2-dev-kit-with-l4t-r32-1/post/5348724/#5348724
https://wireless.wiki.kernel.org/en/users/documentation/aspm
https://elinux.org/Jetson/Nano/Upstream#Linux_kernel
Some cards have issues with PCIe ASPM (Active State Power Management) i.e. even though they advertise that they support ASPM, there would be issues if it gets enabled. I think Intel 3165NGW is falling in that category.
Please use it with ‘pcie_aspm=off’ appended to kernel command line.
I installed Intel 3168NGW (M.2 interface), and was able to establish wifi connection with my wifi router by following softreaper guide. However, I have no internet connection. I have tried my router as well as my phone as a hotspot with no luck. Also, I am not able to ping or ssh to/from jetson within LAN. Does anyone have ideas?
Output of “sudo lspci -vvv”
Latency: 0
Interrupt: pin A routed to IRQ 408
Region 0: Memory at 13000000 (64-bit, non-prefetchable) [size=8K]
Capabilities: [c8] Power Management version 3
	Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
	Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [d0] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Address: 00000000fa81e000  Data: 0001
Capabilities: [40] Express (v2) Endpoint, MSI 00
	DevCap:	MaxPayload 128 bytes, PhantFunc 0, Latency L0s <512ns, L1 unlimited
		ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
	DevCtl:	Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
		RlxdOrd+ ExtTag- PhantFunc- AuxPwr+ NoSnoop+ FLReset-
		MaxPayload 128 bytes, MaxReadReq 128 bytes
	DevSta:	CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
	LnkCap:	Port #0, Speed 2.5GT/s, Width x1, ASPM L1, Exit Latency L0s <4us, L1 <32us
		ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
	LnkCtl:	ASPM Disabled; RCB 64 bytes Disabled- CommClk-
		ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
	LnkSta:	Speed 2.5GT/s, Width x1, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
	DevCap2: Completion Timeout: Range B, TimeoutDis+, LTR+, OBFF Via WAKE#
	DevCtl2: Completion Timeout: 16ms to 55ms, TimeoutDis-, LTR-, OBFF Disabled
	LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
		 Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
		 Compliance De-emphasis: -6dB
	LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete-, EqualizationPhase1-
		 EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
Capabilities: [100 v1] Advanced Error Reporting
	UESta:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
	UEMsk:	DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
	UESvrt:	DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
	CESta:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
	CEMsk:	RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
	AERCap:	First Error Pointer: 00, GenCap- CGenEn- ChkCap- ChkEn-
Capabilities: [140 v1] Device Serial Number fc-44-82-ff-ff-78-95-24
Capabilities: [14c v1] Latency Tolerance Reporting
	Max snoop latency: 0ns
	Max no snoop latency: 0ns
Capabilities: [154 v1] L1 PM Substates
	L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
		  PortCommonModeRestoreTime=30us PortTPowerOnTime=60us
	L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
		   T_CommonMode=0us LTR1.2_Threshold=0ns
	L1SubCtl2: T_PwrOn=10us
Output of “ifconfig”:
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
 inet 192.168.8.127  netmask 255.255.255.0  broadcast 192.168.8.255
 inet6 fd84:7637:68b:5600:9286:288e:938c:112d  prefixlen 64  scopeid 0x0<global>
 inet6 fe80::1999:7d2a:85ea:ace1  prefixlen 64  scopeid 0x20<link>
 ether fc:44:82:78:95:24  txqueuelen 1000  (Ethernet)
 RX packets 2370  bytes 288843 (288.8 KB)
 RX errors 0  dropped 0  overruns 0  frame 0
 TX packets 1062  bytes 177537 (177.5 KB)
 TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
My /boot/extlinux/extlinux.conf file looks like this:
TIMEOUT 30
DEFAULT primary
MENU TITLE L4T boot options
LABEL primary
  LINUX /boot/Image
  INITRD /boot/initrd
  APPEND ${cbootargs} quiet pcie_aspm=off
