How can I get my Intel AC 8265 NGW (M2) to work in master mode (running as access point with hostapd) on a Xavier AGX?
I’m running Jetpack 4.4. I’m hitting the exact same problems described in this thread:
The solution in this thread was to swap the wifi card for another one that works. Well, I bought one that doesn’t work, and how can I tell the next one I buy will be working?
I have the same issue that country code says “00” for the physical device, instead of “US”.
iw reg get
global
country 00: DFS-UNSET
(2402 - 2472 @ 40), (N/A, 20), (N/A)
(2457 - 2482 @ 20), (N/A, 20), (N/A), AUTO-BW, NO-IR
(2474 - 2494 @ 20), (N/A, 20), (N/A), NO-OFDM, NO-IR
(5170 - 5250 @ 80), (N/A, 20), (N/A), AUTO-BW, NO-IR
(5250 - 5330 @ 80), (N/A, 20), (0 ms), DFS, AUTO-BW, NO-IR
(5490 - 5730 @ 160), (N/A, 20), (0 ms), DFS, NO-IR
(5735 - 5835 @ 80), (N/A, 20), (N/A), NO-IR
(57240 - 63720 @ 2160), (N/A, 0), (N/A)
phy#0 (self-managed)
(2402 - 2482 @ 40), (6, 22), (N/A), AUTO-BW, NO-HT40PLUS, NO-80MHZ, NO-160MHZ
(5170 - 5250 @ 80), (6, 22), (N/A), NO-OUTDOOR, AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5250 - 5330 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5490 - 5730 @ 80), (6, 22), (0 ms), DFS, AUTO-BW, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5735 - 5815 @ 80), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40PLUS, NO-160MHZ, PASSIVE-SCAN
(5815 - 5835 @ 20), (6, 22), (N/A), AUTO-BW, IR-CONCURRENT, NO-HT40MINUS, NO-HT40PLUS, NO-80MHZ, NO-160MHZ, PASSIVE-SCAN
and the card cannot be set into master mode, meaning I cannot use it as an access point
sudo iwconfig wlan0 mode master
Error for wireless request "Set Mode" (8B06) :
SET failed on device wlan0 ; Invalid argument.
dmesg | grep iwlwifi shows this that the driver looks for fairly old firmware versions, and eventually loads version 22. Is that firmware supposed to work?
[ 6.974895] iwlwifi 0003:01:00.0: enabling device (0000 -> 0002)
[ 6.982675] iwlwifi 0003:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 6.982870] iwlwifi 0003:01:00.0: Falling back to user helper
[ 8.083088] iwlwifi 0003:01:00.0: Direct firmware load for iwlwifi-8265-25.ucode failed with error -2
[ 8.083286] iwlwifi 0003:01:00.0: Falling back to user helper
[ 8.226086] iwlwifi 0003:01:00.0: Direct firmware load for iwlwifi-8265-24.ucode failed with error -2
[ 8.226285] iwlwifi 0003:01:00.0: Falling back to user helper
[ 8.229095] iwlwifi 0003:01:00.0: Direct firmware load for iwlwifi-8265-23.ucode failed with error -2
[ 8.229272] iwlwifi 0003:01:00.0: Falling back to user helper
[ 8.459747] iwlwifi 0003:01:00.0: loaded firmware version 22.361476.0 op_mode iwlmvm
[ 8.498024] iwlwifi 0003:01:00.0: Detected Intel® Dual Band Wireless AC 8265, REV=0x230
