WiFi6 + Bluetooth5 M.2 key E adapter recommendation
can anyone suggest an M.2 key E format WiFi6 + BT5 adapter which works with Jetson Orin and JetPack 5.x ?
I tried U-Blox Jody-W377 and the bluetooth part didn’t work. BT goes over UART and the hci_uart driver would need an NXP patch which I couldn’t find.
It seems that Intel AX210 is supported by Linux kernel 5.10. Both the WiFi and the BT interface. Can somebody confirm this?
The SCL of Orin NX is as below. Please refer to that. If you can not find what you want there, you can check with the vendors in ecosystem.
