Will AGX Orin still work fine on P2822_B03?
Will AGX Orin still work fine on P2822_B03 ? I simply want to make sure when AGX Orin is populated on the old AGX Xavier’s carrier, it still works fine (power sequence, pcie, usb, eth, hdmi,should be fully functional).
Customers should use the Jetson AGX Orin Developer Kit to test out the Jetson AGX Orin module.
so, will NVIDIA release the schematics of the orin carrier board ?
That will be the same as previous Jetson module/devkit to release them at download center once it’s ready.
