Finally I did it!
The recipe is:
FreeBSD 8.0 + NVidia driver 195.22 + CUDA 3.0
Also linprocfs and linsysfs should be mounted
And, VOILA:
uname -a
FreeBSD av429635.oops 8.0-RELEASE FreeBSD 8.0-RELEASE #0: Sun Feb 7 17:30:12 MSK 2010 root@av429635.oops:/usr/src/sys/i386/compile/ALECN80 i386
./deviceQuery
CUDA Device Query (Runtime API) version (CUDART static linking)
There is 1 device supporting CUDA
Device 0: “GeForce 9400 GT”
CUDA Driver Version: 3.0
CUDA Runtime Version: 3.0
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 1
Total amount of global memory: 536150016 bytes
Number of multiprocessors: 2
Number of cores: 16
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.37 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: No
Compute mode: Default (multiple host threads can use this device simultaneously)
Test PASSED
Press ENTER to exit…
./bandwidthTest
Running on…
device 0:GeForce 9400 GT
Quick Mode
Host to Device Bandwidth for Pageable memory
^C
sudo su
Password:
av429635# mount /compat/linux/proc/
av429635# mount /compat/linux/sys/
av429635# ee /etc/resolv.conf
av429635# exit
./bandwidthTest
Running on…
Quick Mode
Transfer Size (Bytes) Bandwidth(MB/s)
33554432 2766.1
Quick Mode
Device to Host Bandwidth for Pageable memory
33554432 2212.2
Quick Mode
Device to Device Bandwidth
33554432 7996.2
&&&& Test PASSED
./MonteCarlo
Generating input data…
Allocating memory…
Generating normally distributed samples…
Running GPU Monte Carlo…
Options : 256
Simulation paths: 262144
Time (ms.) : 49.021999
GPU options per sec.: 5222.145228
GPU Monte Carlo vs. Black-Scholes statistics
L1 norm : 3.065659E-06
Average reserve: 370.890907
TEST PASSED
CPU Monte Carlo vs. Black-Scholes statistics…
L1 norm: 2.974551E-06
Average reserve: 386.877376
CPU vs. GPU Monte Carlo statistics…
L1 norm: 9.326344E-08
Shutting down…
Well, not exactly “CUDA work on FreeBSD” - it’s Linux program that use Linux libs under Linuxlator on FreeBSD that works.
Also I didn’t try to compile Cuda programs yet, I’ve just launched programs pre-compiled on Linux (Debian)
