hi,
i am working test5 by custom models, i have to update lib file to run that.
if i update lib file at /opt/ path of my NX, can it update same file automatically in docker?
and i have to run deepstream in docker.
thanks!
hi,
thanks!
• DeepStream Version
• TensorRT Version
jetson nx and deepstream-5.1
thanks!
Can you add some log to check it?
hello,
if i run custom test-5 on my jetson nx, timestamp is correctly.
and i pull docker images of NVIDIADeepStreamSDK from microsoft market to run test5 at docker, then timestamp is wrong.
so i think this is image problem only.
can you show me how to make my own deepstream docker images from my custom Deepstream on jetson nx?
thank you very much!
pls forget the topic, it is my own problem and works right now.
thank you
