Will NVFAN ERROR cause Jetson_AGX_Orin restart?
Will the orin restart when we unplug the fan wire harness? At this time the temperature is about 70℃:(CPU@70C Tboard@54C SOC2@64.468C Tdiode@57.5C SOC0@65.312C CV1@-256C GPU@65.656C tj@70C SOC1@64.281C CV2@-256C)
As the pic shows after ‘stopping’ it will restart
Is the restart caused by NVFAN ERROR or other ERROR(such as high temperature )?
Not sure what the issue is. Please describe the situation step by step for our information. Thanks.
First, we cancel the fan of module ,unplug the fan connect. Then, sudo egrep -a FAN /var/log/syslog. The NVFAN ERROR appeared.
When we use ‘tegrastats’ check the temperature it say : CPU@70C Tboard@54C SOC2@64.468C Tdiode@57.5C SOC0@65.312C CV1@-256C GPU@65.656C tj@70C SOC1@64.281C CV2@-256C
And soon it restart
Sorry for the late response, have you managed to get issue resolved or still need the support? Thanks
