Will the “ nvidia,disable-clock-request; ” parameter be valid
Version: R35.2.1
PCIE C0 Device Tree :
pcie@14180000 {
	status = "okay";
	nvidia,disable-aspm-states = <0xf>;
	nvidia,enable-power-down;
#if TEGRA_PCIE_VERSION >= DT_VERSION_2
phys = <&p2u_hsio_2>, <&p2u_hsio_3>, <&p2u_hsio_4>,
<&p2u_hsio_5>;
phy-names = “p2u-0”, “p2u-1”, “p2u-2”, “p2u-3”;
else
phys = <&p2u_2>,
<&p2u_3>,
<&p2u_4>,
<&p2u_5>;
phy-names = “pcie-p2u-0”, “pcie-p2u-1”, “pcie-p2u-2”, “pcie-p2u-3”;
endif
Will the “ nvidia,disable-clock-request; ” parameter be valid ?
kernel/nvidia/drivers/pci/dwc/pcie-tegra.c and kernel/nvidia/drivers/pci/host/pcie-tegra-dw.c not used.
not quite sure about your question. I still see the driver use this property.
kernel-5.10/drivers/pci/controller/dwc/pcie-tegra194.c does not resolve the " nvidia,disable-clock-request; " parameter,
Is PCIE clock-request always enabled ?
xavier PCIE C0 link EP device, EP PEX_CLK0_P don’t have clk.
I just double confirmed. This is deprecated and not in use.
supports-clkreq will be used to do the opposite behavior in latest driver.
Are PEX_C0_CLKREQ and PEX_C0_RST enabled by default in R35.2.1?
