I have been going through many of the posts here, but could not yet find a solution how to compile *.cu from within Matlab. I have tried all version of nvmex.pl, and always getting erros. I use CUDA Toolkit 2.3 and all examples are compiled fine under Microsoft Visual Studio 2008.
When I invoke this line: nvmex -f mexopts.bat bilininterp.cu -IC:\cuda\include -LC:\cuda\lib -lcudart
I am getting the error:
cl : Command line warning D9024 : unrecognized source file type ‘C:\Users\David.DI\Documents\MATLAB\bilininterp\bilininterp.cu’, object file assumed
cl : Command line warning D9027 : source file ‘C:\Users\David.DI\Documents\MATLAB\bilininterp\bilininterp.cu’ ignored
cl : Command line warning D9021 : no action performed
C:\PROGRA~1\MATLAB\R2009B\BIN\NVMEX.PL: Error: Compile of ‘bilininterp.cu’ failed.
??? Error using ==> nvmex at 206
Unable to complete successfully.
Hello, I am attempting to try out cuda with Matlab under windows 7, and am finding the same problems. I have noticed that you talk about an attached file, but the file itself hasnt been attached. If you could be so kind so as to attach the following files:
nvmex.pl
nvmexopts.bat
nvmex_helper.m
mexutils.pm
And if necessary, the configuration File used by Visual Studio 2008, if you have it working wiht 2008.
