Win-SDK Errors When Building Omniverse kit-106.0.3
I have been trying to follow this set up guide for streaming omniverse applications to the Apple Vision Pro: Set Up Omniverse SDK — Spatial Streaming for Omniverse Digital Twins Workflows
When I get to the build step, I get this error:
I have tried to find a version of WinSDK that matches the version required here, but cannot find it.
I have tried installing different versions with no avail.
Any help or suggestions here would be awesome.
Thanks in advance!
hey @walker.mckee
Which WinSDK versions did you install and how did you install them?
I have installed Windows 11 SDK 10.0.22621.0 from the Visual Studio Installer. Should I try a different version?
Hey @walker.mckee
Thanks for the info!
Looks like the script is specifically looking for 10.0.19608.0, so even though you’ve installed a newer SDK, it is failing when kit-app-template cant find 10.0.19608.0 via packman.
You can try version 10.0.19041.0 - which is known to work in many Kit builds -
(reference: kit-app-template/readme-assets/additional-docs/windows_developer_configuration.md at main · NVIDIA-Omniverse/kit-app-template · GitHub)
You can also try explicitly specifying in repo.toml - kit-app-template/repo.toml at 8d8781f9ac2df063e95bf13a4488b36ff2484ede · NVIDIA-Omniverse/kit-app-template · GitHub
Let me know if either of those solutions work for you :)
Hi @AshleyG_NVIDIA
Thanks for the help, I am using the 106.0.03 branch of the kit-app-template as that is what is used in the guide I linked. The repo.toml file seems to be different on this branch and doesn’t have the lines of code in the one you sent me. I can, however, go to a more recent branch and build it successfully. Do you know if I am able to continue with the guide a newer branch? Or do I need to figure out how to build it on 106.0.03?
The last time this guide was checked, it was against 106.0.3 so I cannot say for sure that the guide will still work with a newer version, such as107 - as there may have been minor changes to the XR configurations. However, I would encourage you to move forward with your working branch and report back if you are experiencing issues
