Win7, adding CUDA support in existing program.
I want to add CUDA support in my x64 program without creating new project. So I added paths and files in Additional Dependencies and Include/Library) Directories. Cuda.h - included. I added code from http://llpanorama.wordpress.com/2008/05/21…t-cuda-program/ but I got errors (error C2065: ‘blockIdx’ : undeclared identifier etc.) - probably because I didn’t added sth in command line to compile code using nvcc. I found http://www.microsoft.com/communities/newsg…p;sloc=&p=1 So now I have x64 CUDA rule, I created new .cu file with CUDA instead C/C++ Compiler Tool. In .cu file I have only function -
__global__ void square_array(float *a, int N)
but in .cpp file I can’t use
square_array <<< n_blocks, block_size >>> (a_d, N);
because of errors:
Everything compiles and links without it bud of course it don’t works correctly because GPU does nothing (without probably copying data). So what to do fix it. Do I need do sth else to “connect” my .cu file? Maybe It’s wrong method and I must create new project etc.?
extern "C"
void calculateOnGPU(float *a, int N, int block_size, int n_blocks);
in .cpp
and adding
extern "C"
	square_array <<< n_blocks, block_size >>> (a, N);
in .cu - and all works.
