Window handle of nv3dsink
I would like to get the window handle that nv3dsink uses to render the video. How can I do that from C / C++?
For setting properties to a gstreamer plugin, you can call g_object_set(). The following properties are supported:
  window-x            : X coordinate of window
                        flags: readable, writable
                        Unsigned Integer. Range: 0 - 2147483647 Default: 0
  window-y            : Y coordinate of window
  window-width        : Width of window
  window-height       : Height of window
Thank you,
that was my first solution, but I also need to be able to raise and lower the window. Therefore I would like to get the window handle to be able to call, for example, XRaiseWindow() on it.
Because the plugin implements the gstvideooverlay interface I have now implemented a more complex solution by creating my own window and then passing my window handle to the nv3dsink. Thus I have control over the window.
But it would be interesting to know if there is a better / simpler solution to control also the window layering.
