Window->Physics menu sub-items do not make windows visible
If I enable the Physx bundle extension so that the Window->Physics menu item is visible, clicking on any of its sub-menu items does not do anything. The items are not checked, there are no error messages, it’s as if I didn’t click on anything. Enabling the physx bundle extension in Kit and Create works fine. I’m attaching the warning and error logs from an entire session below and am happy to help with any debugging.
2022-04-09 20:41:15  [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored):  3Dconnexion KMJ Emulator [03000000efbe00006d04000000000000]
2022-04-09 20:41:15  [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored):  SpaceMouse Compact [030000006f25000035c6000000000000]
2022-04-09 20:41:15  [Warning] [omni.ext.plugin] [ext: omni.usd-1.4.7] 'c:/users/eric/appdata/local/ov/pkg/code-2022.1.0/kit/plugins' in '[[native.plugin]]' was not found.
2022-04-09 20:41:15  [Error] [rtx.optixdenoising.plugin] [Optix] [ERROR] Error initializing RTX library
2022-04-09 20:41:15  [Error] [rtx.optixdenoising.plugin] optixDeviceContextCreate(cuCtx, &options, &m_optixContext[d]) failed. Optix Error: OPTIX_ERROR_INTERNAL_ERROR.
2022-04-09 20:41:15  [Error] [rtx.optixdenoising.plugin] Internal error
2022-04-09 20:41:15  [Warning] [rtx.optixdenoising.plugin] Failed to initialize OptixDenoiserContext.
2022-04-09 20:41:15  [Warning] [carb.scenerenderer-rtx.plugin] Creating rtx::optixdenoising::OptixDenoiserContext failed. Denoising with optix is disabled.
2022-04-09 20:41:24  [Warning] [omni.ui.scene.python] The property 'SceneView.view' is deprecated. Please use the model.
2022-04-09 20:41:24  [Warning] [omni.ui.scene.python] The property 'SceneView.projection' is deprecated. Please use the model.
I was able to reproduce the issue, we will investigate and try to fix it, thanks for reporting!
Ales
this will be fixed in the next release (actually the whole Windows menu is getting a bit of restructuring), thanks for the report and sorry for the inconvenience!
