praveenreddy@Quadro:/usr/local/driveworks/bin$ ./sample_hello_world
Welcome to Driveworks SDK
[12-02-2020 15:08:56] Platform: Detected Generic x86 Platform
[12-02-2020 15:08:56] TimeSource: monotonic epoch time offset is 1581535439511815
[12-02-2020 15:08:56] Platform: number of GPU devices detected 1
[12-02-2020 15:08:56] Platform: currently selected GPU device discrete ID 0
[12-02-2020 15:08:56] SDK: Resources mounted from /usr/local/driveworks-2.2/data/
[12-02-2020 15:08:56] Initialize DriveWorks SDK v2.2.3136
[12-02-2020 15:08:56] Release build with GNU 7.4.0 from heads/buildbrain-branch-0-gca7b4b26e65
Context of Driveworks SDK successfully initialized.
Version: 2.2.3136
GPU devices detected: 1
Device: 0, Quadro GP100
CUDA Driver Version / Runtime Version : 10.2 / 10.2
CUDA Capability Major/Minor version number: 6.0
Total amount of global memory in MBytes:16277.2
Memory Clock rate Khz: 715000
Memory Bus Width bits: 4096
L2 Cache Size: 4194304
Maximum 1D Texture Dimension Size (x): 131072
Maximum 2D Texture Dimension Size (x,y): 131072, 65536
Maximum 3D Texture Dimension Size (x,y,z): 16384, 16384, 16384
Maximum Layered 1D Texture Size, (x): 32768 num: 2048
Maximum Layered 2D Texture Size, (x,y): 32768, 32768 num: 2048
Total amount of constant memory bytes: 65536
Total amount of shared memory per block bytes: 49152
Total number of registers available per block: 65536
Warp size: 32
Maximum number of threads per multiprocessor: 2048
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): 1024,1024,64
Max dimension size of a grid size (x,y,z): 2147483647,65535,65535
Maximum memory pitch bytes: 2147483647
Texture alignment bytes: 512
Concurrent copy and kernel execution: Yes, copy engines num: 2
Run time limit on kernels: Yes
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Disabled
Device supports Unified Addressing (UVA): Yes
Device PCI Domain ID: 0, Device PCI Bus ID: 158, Device PCI location ID: 0
Compute Mode: Default (multiple host threads can use ::cudaSetDevice() with device simultaneously)
Concurrent kernels: 1
Concurrent memory: 1
[12-02-2020 15:08:56] Releasing Driveworks SDK Context
Happy autonomous driving!
praveenreddy@Quadro:/usr/local/driveworks/bin$ ./sample_drivenet
WindowGLFW: Failed create window
terminate called after throwing an instance of ‘std::exception’
what(): std::exception
Aborted (core dumped)
