Hi there,
Here are some details regarding my system setup:
OS: Windows 10
GPU: GeForce GTX 1050
Visual Studio 2017 Community Edition with ‘Desktop Development with C++’ workload installed
I did a standard install of the CUDA Toolkit today, and it appears to have been installed, based on the fact that when I type
nvcc -V
on the command line, it outputs
Copyright (c) 2005-2018 NVIDIA Corporation
Built on Sat_Aug_25_21:08:04_Central_Daylight_Time_2018
Cuda compilation tools, release 10.0, V10.0.130
My problem is when I try to open the example code provided in the toolkit. I can navigate to
C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.0 and find the VS .soln files for the example code, but when I try to open them in VS, I get the following error:
C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.0\1_Utilities\deviceQuery\deviceQuery_vs2017.vcxproj : error : Unable to read the project file “deviceQuery_vs2017.vcxproj”.
C:\ProgramData\NVIDIA Corporation\CUDA Samples\v10.0\1_Utilities\deviceQuery\deviceQuery_vs2017.vcxproj(37,5): The imported project “C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\BuildCustomizations\CUDA 10.0.props” was not found. Confirm that the path in the declaration is correct, and that the file exists on disk.
When I navigate to the ‘BuildCustomizations’ directory listed in the error message, that directory exists, along with a number of .props files, but the CUDA 10.0.props file does not exist.
Can anyone help me figure out how to fix this installation? I used all of the default settings when installing the CUDA Toolkit.
