This seems to be a new problem since I used to be able to run cuda programs overnight without issue. Now if the screen power saver triggers on windows 10 kernels fail to launch. One solution is obviously to disable the “turn off the display” after x minutes in Windows, but I’m wondering if anyone has a better solution.
Related topics
Topic | Replies | Views | Activity | |
kernel running makes windows system unresponsive | 4 | 4664 | November 24, 2009 | |
Help me about "Launch timeout error" Launch timeout error | 3 | 3704 | September 16, 2009 | |
Screen stuck | 0 | 2746 | August 3, 2009 | |
Surprising screensaver interaction | 2 | 2910 | June 30, 2008 | |
CUDA kernel timeout | 12 | 58726 | December 22, 2022 | |
Kernel can not launch | 2 | 3849 | October 27, 2008 | |
Display unresponsive when running CUDA on one platform, but not on a less capable platform | 2 | 510 | September 7, 2016 | |
Device blocking while evaluating kernel Intended operation? | 2 | 1674 | September 29, 2011 | |
Black screen when running CUDA 11.2 code on a Windows 10 system with two RTX 2080tis | 0 | 454 | February 12, 2021 | |
Avoiding driver timeouts How do I avoid driver timeouts? | 7 | 7469 | July 1, 2010 |
